01-09-2017, 08:17 PM   #1
HD DA 20-40mm Lens Cap Tip/Advice for those who experience it falling off
Hi Everyone,
I have found that when twisting the the lens cap, while on the lens, there is some type of seal created. And at least on my copy, the lens cap is much harder to fall off. Hope this helps those that experience this issue!
Just wanted to share this little piece of advice.
-Justin
01-09-2017, 11:51 PM   #2
The grooves in the spring-loaded tabs that push out against the filter threads are probably making better contact against the lens. I've found it necessary to do this on a couple lenses where it's been obvious the cap, for whatever reason, simply doesn't want to go right up against the end of the lens.
01-10-2017, 01:38 AM   #3
microlight's Avatar
Justin, are you referring to the push-on metal lens cap with the felt ring? Fortunately mine hasn't loosened yet - but I had a funny experience with it a couple of days ago climbing over a stile, when the end of a small springy branch got caught under the edge of the hood and flipped it into the air, which my wife then caught!
01-10-2017, 12:53 PM   #4
wstruth's Avatar
I've been using a lens keeper on mine.
01-10-2017, 09:23 PM   #5
Microlight, I'm referring to the push-on metal lens cap, with Pentax embossed. I think the felt is able to keep an air-tight seal. Hahaha, glad you were able to catch it!
LowVoltage, I think you're talking about the plastic lens caps with Pentax written in silver?
20-40mm lens cap, cap, da 20-40mm lens, experience, hd da 20-40mm, k-mount, lens, lens cap tip/advice, pentax lens, slr lens
For Sale - Sold: Black HD DA Pentax 20-40mm manishved Sold Items 15 08-04-2016 09:30 AM
For Sale - Sold: FS: DA HD 20-40mm f2.8-f4 WR Limited Lens Dirtistasty2 Sold Items 8 07-24-2015 12:14 AM
HD DA 21mm Limited vs. HD DA 20-40mm Limited seachongo Pentax SLR Lens Discussion 10 05-09-2015 11:18 PM
Hot tip for those who use the A7 and A7r with adapted lenses - Lens compensation Christine Tham Non-Pentax Cameras: Canon, Nikon, etc. 2 02-04-2014 01:58 PM
Is there a store who has the HD DA 20-40mm in stock? brosen Pentax SLR Lens Discussion 5 12-17-2013 04:57 AM
All times are GMT -7. The time now is 05:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
