01-11-2017, 02:22 PM   #1
Digitiser of Film
BigMackCam's Avatar
Tamron 28-75 f/2.8 lens problem - de-centering?
I'm hoping one of you good folks can educate me before I send a lens back for replacement or warranty service.
Just after Christmas, I bought a Tamron 28-75 f/2.8 for my A-mount gear, as I've been very happy with that same lens in K-mount.
However, while doing AF accuracy tests I've found a problem. See attached pic... When focused where that red circle is, the field of acceptable focus (if that makes sense) changes across the frame from left to right. On the left side of the shot, you can see the the text in front of the focus point is in focus, while on the right side, the text behind the focus point is in focus. This is very visible with focus peaking in the EVF, without even having to take the shot.
I don't see this with my K-mount copy running the same test with the camera mounted in the same position, nor do I see it with my other A-mount lenses. I can repeat the test with the same result every time.
Is this a de-centering issue, or something else?
01-11-2017, 03:09 PM   #2
MSL
MSL's Avatar
No answers, but in order to aid those who might be able to answer - what were the settings used for this shot, and does this effect occur at different focal lengths?
01-11-2017, 03:12 PM   #3
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by MSL Quote
Apologies, I should have given that info. This was at 75mm, f/2.8. It happens at other focal lengths and apertures too, just with greater overall depth of field as you'd expect...
01-11-2017, 04:12 PM   #4
photoptimist's Avatar
Are you sure everything was square, flat, level, and aligned? It's strange that the vanishing point for the two columns of text seems to point to the right.
01-11-2017, 05:06 PM   #5
I am afraid this is likely a tilted element, which I guess is kind of decentering. Another kind is when the best focus is off the center axis of the lens. I would take a look if there are any signs of the lens falling on the axis of the tilt in the focus field. Another option could be loose cams or maybe busted helicoid. Either way, in my opinion the lens is mechanically damaged.
01-11-2017, 10:30 PM   #6
+1
Chart looks crooked to me.
01-12-2017, 12:40 AM   #7
Digitiser of Film
BigMackCam's Avatar
Not 100% straight, admittedly (my tests were hand-held), but straight enough that I do not get the problem with other lenses in the same test, and the results I'm getting are repeatable.
01-12-2017, 01:48 AM   #8
de-centering issue
If it was de-centering, you should see the problem on a totally flat test target too.
01-12-2017, 02:19 AM - 1 Like   #9
You have it in tilt, first look for the knob on the lens and unlock it and center the lens back to 0
Just kidding, I would look to see if the lens mount is sitting flush with the camera mount or look to see if the lens mount is flat to the lens
01-12-2017, 07:14 AM   #10
Hmmm... That is suspicious. How about at ∞? If you point the camera at a distant horizon, live-view zoom the far right edge and manually focus, then move the zoomed view to the left side, is the left side also in focus or do you have to refocus to get that sharp?
f/2.8, f/2.8 lens, focus, k-mount, lens, pentax lens, slr lens, tamron, tamron 28-75 f/2.8, test, text
Tamron 28-75 f/2.8 $159.88 K57XR Pentax Price Watch 2 10-16-2016 07:19 PM
For Sale - Sold: Tamron SP AF 28-75 mm f/2.8 and Tamron 90 mm f/2.8 macro lens Vantage-Point Sold Items 5 03-22-2012 03:35 PM
Tamron Lens 28-75 f 2.8 raslgn Pentax K-5 & K-5 II 8 03-07-2012 07:29 AM
Tamron 28-75 f/2.8 over exposure problem Sew-Classic Pentax SLR Lens Discussion 13 10-22-2009 02:49 PM
All times are GMT -7. The time now is 05:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
