01-11-2017, 07:14 PM   #1
How is your 16-50 autofocus accuracy in S-AF?
Hi,
I am wondering if anyone else has trouble with their AF accuracy on 16-50, specifically in PDAF. It's not a matter of front or back-focus, it just fails a great deal of time, and almost always when using focus points in the corners. It looks great in CDAF, which makes me think it is not mechanics. Anyone got similar experiences?
01-12-2017, 01:34 AM   #2
BigMackCam's Avatar
I don't have the 16-50, however... As you're probably aware, only three middle focus points of the K-3 (that's what you're using, yes?) have a focus sensitivity of f/2.8. The rest - including those in the corners - are rated, I think, at f/5.6, so focusing using those points won't be as consistently precise. I suspect that might be what you're experiencing, and you may notice the problem on any fast lens at wider apertures when using anything but the three central focus points.
01-12-2017, 01:56 AM   #3
I thought so too, initially, but often it is off even at f8, and by a lot. It's to a point where landscape shots are unsharp if I use corner focus points. I wonder if this has happened to anyone before.
01-12-2017, 03:40 AM   #4
BigMackCam's Avatar
QuoteOriginally posted by rrstuff Quote
Hmm... that is a bit odd. Does it happen in good lighting? My Sigma 17-50 sometimes needs a second AF cycle to focus accurately on outer focus points in less-than-stellar light. I've taken to focusing twice out of habit...
01-21-2017, 01:14 AM   #5
UncleVanya's Avatar
I recently converted a working 50-135 that had significant focus issues on SDM to screwdrive. The owner wanted to see if this could improve with Screwdrive- it DID! the change was pretty dramatic. So while it might not help; if you can I suggest trying.
01-21-2017, 07:36 AM   #6
I often have trouble autofocusing my 16-50 towards the short end. It'll often front focus 1-2 meter. I've learnt to anticipate it and work around it by doing the zoom-in-focus-zoom-out-again thing.
I've also experienced the phenomenon described by the OP, with all focus points. I attribute that to an old worn SDM drive.
Regards,
--Anders.
01-21-2017, 08:01 AM   #7
UncleVanya's Avatar
It is important to note that the lens I mentioned above was not sluggish nor squeaking. I compared it to my own 50-135 and the difference on SDM with it giving up on tough focusing situations was clearly and easily seen. Once switched to screw drive this behavior vanished. This was not really something I had ever seen before. Since then others have mentioned similar findings.
accuracy, autofocus accuracy, k-mount, pentax lens, slr lens
16-50 gross AF inaccuracy in PDAF - only in some AF points? rrstuff Pentax SLR Lens Discussion 9 11-19-2016 11:29 AM
How torquey is your K-1's mirror? 6BQ5 Pentax K-1 & K-1 II 7 09-18-2016 10:39 AM
Select AF point(s) vs. single (spot) point ... any difference in accuracy? jpzk Pentax K-3 & K-3 II 35 05-06-2016 05:31 AM
K-5 autofocus accuracy varies by AF point Designosophy Pentax K-5 & K-5 II 22 01-19-2012 08:32 AM
K5 and DA*16-50 ... How's the AF?? germar Pentax K-5 & K-5 II 6 12-20-2010 11:16 AM
All times are GMT -7. The time now is 06:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
