08-04-2008, 06:25 AM   #1
KFrog's Avatar
DA 18-250mm Problem
My Pentax DA 18-250mm zoom lens has decided it doesn't want to zoom anymore. I put it on the camera, unlocked the transport lock and tried to zoom in on something. The focusing ring adjusts itself as before but the lens tubes do not extend out at all like they did before.
My lens has exhibited quite a bit of zoom creep and seems to do so more easily as time has gone on. I've had the lens for 6 months. What's the best process to go through for getting the lens fixed, local camera shop or sending back to Pentax USA?
Thanks
08-04-2008, 07:00 AM   #2
If you bought from a local shop and they are willing to exchange it for a working unit I would go that route. However that probably will not be the case as such I would send it to Pentax directly for an in-warranty repair.
08-17-2008, 07:40 AM   #3
KFrog's Avatar
Thanks for the reply. I will probably send it in to Pentax USA. I wonder if my local Ritz/Wolf Camera will help with this even though I didn't buy it from them... Anyone have any other helpful suggestions?
08-18-2008, 12:09 PM   #4
clawhammer's Avatar
Your local ritz/wolf will probably quote you a $100+ price to fix it. I'd just work with Pentax directly.
08-18-2008, 01:03 PM   #5
Venturi's Avatar
I may send mine in to Denver when I get back from Colorado next week because of the same issue. Too bad the engineers didn't think of putting a simple o-ring on the zoom ring to dampen it, huh.
camera, da, da 18-250mm, k-mount, lens, pentax, pentax lens, slr lens
K-x problem with Tamron 18-250mm (A18) henrywmk Pentax SLR Lens Discussion 3 08-10-2010 09:40 AM
Problem with 18-250mm Pentax xyz100 Pentax SLR Lens Discussion 2 09-09-2009 09:44 AM
18-250mm problem.... Daveinozbikes Pentax SLR Lens Discussion 9 08-01-2009 12:07 AM
All times are GMT -7. The time now is 11:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
