01-16-2017, 09:51 AM   #1
SMC Takumar 135mm f/2.5 (6 element version) disassembly question
Does anybody have experience disassembling this lens? Specifically, I would like to gain access to the inside of the front element to clean off some fungus. Is it as simple as taking off a retaining ring in the front and popping it out or would I need to start back at the mount?
Thanks!
01-16-2017, 10:13 AM   #2
Thanks for the quick response, if you are able to confirm that would be wonderful.
I'm not sure that I would trust myself to do what you're describing (taking apart the barrel and removing the whole front group) without damaging it.
01-16-2017, 10:20 AM   #3
Just1MoreDave's Avatar
The front barrel unscrews so step one is really easy - focus to 5 feet, hold the focus grip in one hand and unscrew the protruding barrel with the other. That lump has the front four elements so you may have more work ahead. I think dcshooter is right, the next step is to start from the back of that assembly and work forward.
Let's see if this picture still works. It's the K version with the front unscrewed but construction is the same.
https://goo.gl/photos/ELvGKXnMBLxMC7Et6
01-16-2017, 03:19 PM   #4
I found it almost impossible to get to the element just in front of the aperture blades when I was cleaning my K135/2.5. It really didn't seem to want to open. The front element group unscrews really easily on that one, as does the rear group with a tool. The middle elements are a pain though.
01-16-2017, 03:57 PM   #5
Thanks everybody.
03-14-2017, 02:41 PM   #6
Finally getting around to this...
Taking advantage of the snow day here in Boston today, I've finally started to open this lens up. I unscrewed the front part of the barrel and started working at the glass in that piece from the rear as recommended. The first element came out without much issue. The second one....has no retainer ring in back and looks like it needs to come out the front instead?
I tried to remove the front retaining ring (name plate) but it's stuck and I'm afraid to really torque down on it. I've got it in a heating pad right now in the hopes that it will loosen up any adhesive that may be working against me.
Any other tips? Am I missing something?
Thanks again!
element, f/2.5 6 element, front, k-mount, pentax lens, slr lens, smc takumar 135mm, takumar 135mm f/2.5
For Sale - Sold: SMC Takumar 135mm f/2.5 - final version, 6-elements, 43812 nugget247 Sold Items 2 02-05-2017 07:18 AM
For Sale - Sold: SMC Takumar 135mm 2.5 w/hood 6 element last version (REDUCED) 17dew Sold Items 22 01-17-2012 07:15 PM
Pentax SMC Takumar 135mm 2.5 6 element version Irishwiseguy Pentax SLR Lens Discussion 10 09-09-2011 11:50 AM
All times are GMT -7. The time now is 06:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
