08-04-2008, 01:56 PM   #1
sabatocd's Avatar
FA* 300mm f/2.8 Question
I have a Pentax FA* 300mm f/2.8 and every time I take the lens hood on or off it get stuck on the rubber that is on the UV filter. Does anyone else have this problem. I took the rubber cover off and I can screw the lens hood on and off with no problem. Has anyone done this? Am I going to regret no having that rubber piece.
08-04-2008, 07:30 PM   #2
Marc Langille's Avatar
QuoteOriginally posted by sabatocd Quote
Hi,
I own the same lens: are you talking about taking it off from the reversed position or the normal mounted position?
Regards,
Marc
08-04-2008, 08:25 PM   #3
sabatocd's Avatar
Yes... It goes on fine in either position, but is a real pain to get off of either position. Half of the time the UV Filter ends up screing off.
08-04-2008, 08:32 PM   #4
I sometimes have difficulty with it going on/off, but I've snugged the UV protective filter down quite well, so it's not much of an issue. I just have to be careful doing it. Generally I don't reverse it any more, unless it's for prolonged storage.
Regards,
Marc
08-04-2008, 09:56 PM   #5
images FA 300?
Could you help to post some images taken with FA 300 f2.8?
marcus
08-05-2008, 03:59 AM   #6
images taken with FA* 300/2.8
QuoteOriginally posted by marcusyoung Quote
marcus
Just posted last night:
https://www.pentaxforums.com/forums/post-your-photos/33849-vlf-photos-k20d-fa...files-1mb.html
Cheers,
Marc
300mm, f/2.8, fa*, fa* 300mm f/2.8, hood, k-mount, lens, pentax lens, rubber, slr lens
70-300mm Lens Question HuskerMann Pentax SLR Lens Discussion 8 09-18-2010 06:54 PM
Sigma 28-300mm lens question adwb Pentax SLR Lens Discussion 0 11-15-2009 11:48 AM
300mm lens question Fl_Gulfer Pentax SLR Lens Discussion 13 08-23-2009 08:22 AM
Question : Takumar 300mm F/4 designinme_1976 Pentax SLR Lens Discussion 5 08-09-2009 08:57 PM
Tamron 300mm F3.5 question eccs19 Pentax SLR Lens Discussion 7 04-14-2009 04:21 AM
All times are GMT -7. The time now is 12:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
