Good evening Pentaxians,
I am considering the purchase of a used copy of the subject lens, but after comparing images to my Tamron 17-50 f2.8 at similar apertures I am at a bit of a loss. The resulting images that I was getting from the Pentax seemed all over the place (soft in the center and sharp on the edge then vice versa) and this may have been a result of the focus, but I am not sure.
The following images (
100% Crop) were
both taken from the same spot at
1/60 sec, f4 - ISO 100. Hand held with K3. There may have been a slight adjustment in focus as the results seem quite different.
Image 1 Center Image 1 Edge Image 2 Center Image 2 Edge
The details in the foreground car tire are very good in image 2, but the edge of image 2 is fairly soft. Vice versa for image 1 as the details in the tire are less but the edges are fairly sharp for the lens being wide open. I also found the images of the Tamron to be over all sharper, but of course its not quite as wide and its bigger and heaver and is not quite as elegant!
Because of these results I am not sure if its worth while to purchase the limited lens or just stick with the Tamron for use as my main landscape lens. It seems that this lens is praised by so many, but I really couldn't take it out of the store in order to test it better, so I am not sure what to do.
Can anyone help me decide please!
