Originally posted by Fenwoodian .
Well said!
I do the same with my most expensive lenses (over $2,000). I suspect some of those saying they'd never use a protect filter don't have lenses that are very expensive.
For sure you are right.
I don't have protective filters for any of my FA LTD lenses (I realize these are neither rare nor expensive), but I have also resisted the siren call of protective filters for my A50/1.2, my A*85/1.4, my A100/2.8 Macro, my FA*200/4 Macro, my F*300/4.5 (I don't know if this classifies as expensive or not), or my much loved A*600/5.6 (which is unusable with a filter anyway).
I also don't have protective filters for the 4 dozen or so more mundane lenses that I own.
---------- Post added 02-19-17 at 10:28 AM ----------
Originally posted by TaoMaas True! Cleaning with dust can cause problems. Use a blower to clean the loose particles from a lens. Then use a soft brush to get rid of remaining particles. Only then should you use a liquid and cloth to remove what's left. And even then you ought to use caution.
And even then, if you do it too often, you will destroy the front surface of the lens.
