01-24-2017, 12:50 PM   #1
Removing Takumar A/M lever?
Some Takumar lenses are so tiny, that they do not cover K-mount when adapted. It even seems that one could insert them into mount of some dead K lens -it seems possible for my Super Takumar 35/3.5 and maybe SMC 28/3.5. The only problem is the auto/manual lever, which I would like to remove (and keep- preferred option) or shave partly (well it hurts me little bit even thinking that way).
I do not see any possibility to open the lenses from the back. Has someone any idea how to do it?
Any tips appreciated!
I really feel uncomfortable leaving the contacts and the whole camera mount not covered, thats why I'm asking.
01-24-2017, 01:08 PM   #2
QuoteOriginally posted by dcshooter Quote
For the shorter focal length Takumars, the process is generally:
1. Remove fornt trim ring
2. remove screws holding front barrel
3. Remove Barrel
4. Remove screws holding focus ring
5. Remove focus ring (mark position for reinstallation later)
6. remove set screws holding DOF scale
7. Remove DOF scale
8. Remove aperture ring (don't lose the ball detent)
9. Remove screws holding mount to main barrel.
Once you complete these steps, you will have access to the two screws that hold the A/M switch to the inner cam ring. Remove them, and the switch will come right off. Reassembly is the reverse of above.
Thank you! Seems little bit complicated - which steps are risky? I suppose the one with aperture ring.
01-25-2017, 10:18 AM - 1 Like   #3
Just1MoreDave's Avatar
I would start with a replacement body cap. If anyone makes one with a WR-type seal on it, that would be nice. Then I'd make a hole in the center that just fits the base of the lens. I'm looking at an S-M-C 105.2.8 lens right now and it seems like there is ~2mm between the bottom of the A/M switch and lens base, so I would leave the switch in place. Then some glue to hold it in place. I don't think you need a total seal here because everyone uses non-WR lenses all the time and they simply cover the contacts.
01-25-2017, 10:50 AM   #4
QuoteOriginally posted by Just1MoreDave Quote
Even though the OP was getting at a seal in this area , something like this could help also to short the contacts to get Green Button metering ? In either case THANKS for the idea as I have a couple taks that I'm getting tired of using aluminum foil on. Gets me to thinking.
I thought about having a couple round spacers made out of very thin steel for this very idea , but when I checked into mass production of a few hundred to resale the cost was prohibitive.
k-mount, lenses, pentax lens, slr lens, takumar, takumar a/m
Removing Super Multi Coated Takumar 28/3.5 Name Ring Dean Bradshaw Pentax SLR Lens Discussion 21 06-14-2019 11:50 PM
Removing rear element in S-M-C Takumar 6x7 1:3.5/55 xyzzy Troubleshooting and Beginner Help 3 12-03-2015 12:06 PM
Removing a Takumar Lens Faceplate Help MobiusOne Pentax SLR Lens Discussion 7 11-07-2011 07:26 PM
Removing rear group from Super-Multi-Coated Takumar 50mm 1.4 xyVy Pentax SLR Lens Discussion 6 08-30-2010 01:39 AM
Pentax K 45-125mm F4 vs Takumar A 28-80mm vs Takumar M 135mm F/3.5 YJD Pentax SLR Lens Discussion 18 10-29-2008 01:35 PM
All times are GMT -7. The time now is 07:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
