Originally posted by madison_wi_gal Went on my western trip. Couldn't decide which 2 or so lenses to bring, so brought ALL of them. (And yes I have been buying more and more, I have the lens bug).
you mean LBA??
Quote: Other than a few test shots, I ONLY used the 10-17 fishie and the 18-135. So I lugged around my 15 and 21 limiteds, my 50 and my 55-300 and my wee 40XS (not a lug in that case but still taking room). Sheesh.
So now I wonder (again) - do I NEED all the other lenses?
Yes, but you need to consider when travelling what you are going to do, and what you need.
I have at last count about 60 lenses, and yes I did have LBA . But I have about 15-20 M42 lenses from 16mm though 300mm, similarly I have manual focus K/KA lenses from 8-400mm plus 70-210mm and 200-500mm zooms
Then I have AF zooms from 10-200mm plus 1.4, 1.7 and 2x converters. (The 1.7x is the Pentax AF converter)
But when I go out, it is somewhat mission oriented, and I take much less.
Travelling, I will take my sigma 10-20, my Tammy 28-75, and if I know there is a wild life portion, I will take my 70-200/2.8 and 2xTC. If there is no wildlife opportunities the 70-200 stays home, but I might slip a couple of KMount primes into the bag.
If I am driving to a destination, as opposed to flying, I might take more, in a hard case, that is locked by cable into my trunk if it is a long trip where I might get out of the car several times between destinations, but I have not done that for a while. Short trips to cottage, etc, I might take most or all of my legacy lenses for either m42 or k mount, just to play.
The other point is, even if I have the 70-200 and the TC with me, unless the hotel or what ever is in a specifically seedy area, I can usually put it in a safe or the room is safe enough etc, that out in the city I don't have it with me. Then I take my 2 bodies,more with each lens, with me on walks, one camera and lens in a shoulder bag, the other in hand.
I find zooms much more convenient for travel, and usually don't need to go over 75-80mm in cities. I have done, for example a up to a week in cities like Paris, Prague, New York, etc, with only 1 body and 2 zooms if I really want to go light because I know the use of anything else is so infrequent it does not matter. I think you found this out.
The other thing to consider, is if you limit your lens selection, it forces you to think in terms of what can you do, in a situation, with what you have right now! It might even make you a better photographer.
Edit note! One thing to consider is whether you have a "home base" when travelling, and the possibility of more than one bag, I.e. One bag or case to get to the temporary home base, where you can carry all your equipment and a second to use when making short trips away from home base, or do you need to carry it all with you all the time! This is a big decider.
