08-05-2008, 10:53 PM   #1
Kiron 105mm F2.8 Macro vs. Voigtlander Lanthar 125mm F2.5
This is a quick test of the two lenses' chromatic aberration properties at two F-stops. Unfortunately, I wasn't entirely thorough and let the camera vary the ISO between shots, and I didn't test the Lanthar wide open at F2.4.
I took two shots (F2.8, F9.5) of a scene with the Kiron, and then moved the tripod back a bit, recomposed, and then took two shots (F2.8, F9.5) with the Voigtlander Lanthar. The move allowed for nearly identical image sizes.
Both lenses are manual focus. Crops are 100% and sharpened on export, otherwise no post-processing.
Gavin's Lens Tests
Conclusion (based on my copies): The Voigtlander has less CA than the 25-year old Kiron (Vivitar Series 1).
Cannot conclude from this test which lens has better bokeh, or edge/center resolution. At any rate, I like'em both!
08-06-2008, 05:14 AM   #2
audiobomber's Avatar
QuoteOriginally posted by gavinhw Quote
Based on these photos the Voigtlander is much sharper.
You didn't mention a tripod, did you use one?
08-06-2008, 05:24 AM   #3
roentarre's Avatar
The thread did not reveal bokeh comparison.
Again, you make a case that Voigtlander 125mm macro is over-rated.
08-06-2008, 05:42 AM   #4
Asahiflex's Avatar
A little offtopic: did anyone notice that the Voigtlander's diaphragm closes when you are focusing towards 1:1? And does the Kiron/Vivitar/Rikenon P/Lester P. Dine/Soligor or whatever it's called the same? Just something I wanted to know as I found the stopping down of the Voigtlander rather odd.
105mm f2.8 macro, f2.8, k-mount, kiron, kiron 105mm f2.8, lanthar, lenses, pentax lens, shots, slr lens, test, voigtlander
Voigtlander 125mm f2.5 Apo Lanthar SL II macro is so sharp! roentarre Pentax SLR Lens Discussion 27 05-17-2010 04:20 AM
For Sale - Sold: Voigtlander APO-Lanthar 125mm F2.5 SL Macro mikeatnite Sold Items 6 03-22-2009 02:21 PM
All times are GMT -7. The time now is 12:07 AM. | See also: NikonForums.com, part of our network of photo forums!
