I guess it's "finding" rather than "fining".
You typed it on a cellphone, isn't it?
I've seen few Sigma's in Pentax mount during the last few years. I think you just need to be patient. You'll eventually find one.
I have many converters in PK mount, most with electric contacts.
I haven't used most of them long enough to provide reliable and detailed informations about their performance with different lenses.
Most of them are in the lens list in my signature.
What I know about teleconveters is that it is not all about sharpness.
It is possible, and sometimes even evident, that a 1.4x, 1.5x or 2x crop equals or even beats the sharpness obtained by the use of a corresponding converter, but it's also true that the image is DIFFERENT.
The bokeh and the transition between in focus and OOF are rendered in a different way.
If you use the viewfinder the size of the subject makes a difference too. Focus and composition can benefit from a larger image, if the image is not too dark.
The 1.7x is a different beast, can't be compared with all the others because it gives AF to MF lenses. Using it as a "normal" converter is a nonsense.
I have found that the grey "-L" converters work very very well with the objectives they were designed for.
I have not enough experience with "-S" converters to go into details, but I'm sure that I have many lenses that work better (especially with the 1.4x) than cropped.
The 7 elements macro converters, like the Vivitar/Kenko/etc with helicoid, or the Panagor/Elicar/etc with floating elements are also quite good, and very useful.
In these days I'm using a Kenko AF PKA-Pz mounted on the the first version of the Tamron 90mm Macro AF, which shares the optics of the early 2.5/90mm MF ones.
It's a bit soft wide open, but the OOF rendition and the sharpness at medium apertures are really impressive.
You also won't get the "light spot" at the center of the frame that sometimes shows up in certain lighting conditions.
If I cropped the 2.5/90mm Macro many pictures would have been very different.
Cheers
Paolo
