Originally posted by hopkins802 I have the 200mm 3.5, so that's fine.
---------- Post added 02-10-17 at 01:08 PM ----------
Thanks! Yeah man, I would love for you to send me your supplies and I will give it a shot!
I really appreciate it!
While I've got you..I also need to find a good lens hood.. There is a good one on B&H for $40 and some very similar ones on eBay for about $10. How deep is the original lens hood?
Ok. I have Your address so go ahead and delete it from the Post so 1 million others DONT have it too !
I also added the threaded knob from another project and will include a socket screw and washers to mount it to a tripod Plate. I also will trim down the ears on the bracket so there is No clearance issue for your camera just in case.
I also cut and glued the thick Felt to the bracket to keep it in place.
Its now Complete 100%. Worse case scenario is there could be a clearance issue with the knob on your camera Body , but that can be replaced on your end easily at a Hardware store.
I will get it shipped out to you on Monday.
My original Hood isn't marked with a mm size , but is about 2.75" deep and the end is about 1/2" larger in diameter than the lens filter size .
I wouldn't spend more than about $10 for a Generic hood from Ebay or Amazon. Just make sure and get one that is slightly flared on the end. Being a tele it isn't going to be a critical decision at all.
ALSO...NOTE. When using the lens on my K3II , K30 , or K-1.... the lens does NOT cover (short) the electric contacts using a M42 adapter. I have to short my contacts to get the Green Button Pentax Metering with a piece of aluminum foil or aluminum backed tape. I have no idea what camera your using so just ask if help is needed in this area.
