Originally posted by Simen1 Ok, I did stretch it a bit. My point is being that I'm primarily looking for a larger weight difference. If the weight difference becomes small (825 gram lens in stead of 500g), I become picky, like not having to sacrifice zoom. Another thing is that I don't mind smaller aperture for such a lightweight alternative to the Sigma 70-200. I feel that f/2,8 is more then I need, and make it more expensive then what I had in mind.
The 200 with TC gives you all of that. With the 1.4 and 1.7 stacked you have 476 mm, ƒ6.3, but you also have the option of the 1,7 for 340mm at ƒ4.5 or the 1.4 at 280mm and ƒ4. You can have you small aperture long lens and wide aperture in one lightweight portable package probably less than you Sigma 70-200. With the 200 you can go more twice as long as the 70-200 with less weight, but the composition is pricey.
The thing about the 200 is it has large from element, but not a lot of weight behind it. You aren't going to find a more efficient use of a large front element.
This is the tipping point for effective long glass. Anything cheaper isn't wide enough to take stacked TCs, any thing longer is much heavier (6 pounds of my Tammy 300 2.8.)
My F 70-210 is 555 grams compared to 825, but you can't put a TC on it, and it's ƒ5.6 at 210mm wide open.
There is nothing for Pentax like my 28-105 (or 18-135) and the 200 plus TCs for weight to versatility ratio.. No long zoom package even comes close.
The 200 improbably the most efficient use of large front element with not a lot of weight behind it.
So are you serious about the weight, or aren't you?
The DA 55-300 PLM is 442 grams and ƒ6.3. IN terms of IQ, that's your next choice, but at ƒ6.3 even a 1.4 TC is going to seriously degrade AF. So 300mm is where it ends. But if you're happy with that, that's your choice. I'm thinking of picking one up for bright sunny days when I don't want to carry even the 200.
