Originally posted by dcshooter Even worse, the auction states it's from a Bolex L-8 which has a shorter-than standard variant of the D mount (a mere 7.8mm FFD!). Even if it were a C, there's no practical way to adapt this lens to K-1, since the entire lens would be sitting inside the mirror box, and the image circle won't even come close to covering a 35mm sensor. If you are lucky, the lens was on an L-8 to standard D adapter, and you can at least use it on Q or m4/3. K-1 ain't happening.
I've seen some of the 4" Cooke Panchrotal C mounts
converted to Nikon F, but they have a large rear barrel that can be milled down. I actually have one I've been toying with the idea of converting to K, but that's a project that will have to wait all of my others (including a Kern Macro Switar K conversion) are done.
Thanks for the expert advice DC!
Sounds like the K1 ain't going to happen.
... There's no way that I'd risk putting this lens "inside the mirror box" of my K1 and use it in live view mode.
So, on to plan B - I'll try to make it work on my Fuji XE1 mirrorless body.
If that doesn't work, I'll go to plan C - buying a Pentax Q or a m4/3 just for this lens.
Stay tuned...
