02-14-2017, 12:53 PM   #1
W.j.christy's Avatar
Use of Tokina 28-70 AT-X F2.8 Pro II (OR AT-X 270 Pro II)
I had been looking for a lens in the 24-70 F2.8 genre for some time. I originally was going to go after the HD-DFA 24-70 but, honestly, I am not a pro and I truly can't justify that cost.
I had looked at the sigma in both the screw drive and HSM as well as the tamron. I didn't go with the sigmas as they were both cost prohibitive relative to their IQ. Which left the tamron, which I bought used.
The tamron arrived and it was damaged straight off, loose barrel and a crack near the filter ring... Not good, so it's getting returned. I was also not impressed with the build quality overall.
I did some more digging and came across the Tokina 28-70 F2.8 AT-X Pro version 2 (it has the bayonet mount hood). The more I looked into it the more it seemed like a viable option. The pictures I saw with it had great color, and supposedly when its stopped down it is pretty sharp throughout the range (according to photozone.de). Its also all metal construction and reportedly "built like a tank". So I bought one.
These lenses are known for both flare, and CA. The flare is handled by buying a different hood according to several posts and reviews I have read, but the CA at 28mm and F2.8 is hard to correct for. Yes, it can be handled in PP but I like to try to get the shot as close to perfect as possible before going to PP. Further, stopping down doesn't help the problem, it makes it worse.
Given the above I know there are folks here on this forum who use this lens, and was hoping for some pointers to help me reduce/eliminate the CA and flare issue. I have seen many of the pictures taken from this lens in the ATX pro lens club and they are gorgeous. Any help from you guys would be great!
02-14-2017, 01:19 PM   #2
Unrelated, but you might get better image quality at a lower cost with the D FA 28-105mm, if you're fine with the slower aperture.
02-14-2017, 01:35 PM   #3
Plus One on What He Said...^^^^^^^
02-14-2017, 01:42 PM   #4
jlstrawman's Avatar
No question about Adam's assessment. Lots of bang for the buck.
02-14-2017, 01:52 PM   #5
I looked into the 28-105. I decided against it because of the smaller no-constant aperture. I also like the bokeh and rendering of the tonkina more than that of the 28-105....
02-14-2017, 03:25 PM   #6
there was also sigma 24-60 f2.8 which should be cheaper. Not sure about the quality.
02-14-2017, 03:57 PM   #7
Though I am grateful for the alternate lens suggestions, I have already purchased the Tokina and am looking forward to using it.
What I am really looking for is, advice on how to work with or mitigate, what I feel, are minor weaknesses and squeeze the most I can out of what appears to be a rather good lens.
Again, thank you for the lens suggestions, but I would appreciate it if we could stick the above topic.
02-14-2017, 05:19 PM   #8
clackers's Avatar
QuoteOriginally posted by rrstuff Quote
I picked up one real cheap. My copy isn't decentred, but it's IQ is less than the 18-55. Good luck to anyone else!
02-15-2017, 04:15 PM   #9
mbukal's Avatar
I use the Tokina AT-X PRO SV 28-70 / 2.8 + Hoya HMC UV (c) 77mm on Pentax K30 and I can only say that it is "a little soft" on the 2.8, remained only words of praise for this lens (ignoring large weight construction that provides the safety in the use of), I used it and on the Pentax K1 when photographing weddings in combination with HD Pentax-D FA 15-30mm F2.8 ED SDM WR, again only the words of praise
at-x, at-x f2.8, f2.8, f2.8 pro ii, flare, help, ii or at-x, k-mount, lens, pentax lens, slr lens, tamron, tokina 28-70 at-x
Wanted - Acquired: Tokina at-x 28-70/2.6-2.8 PRO I or II repaap Sold Items 4 04-05-2012 03:40 AM
For Sale - Sold: Tokina 28-70/2.8 AT-X Pro II photoracer Sold Items 2 09-15-2011 05:55 PM
Wanted - Acquired: Tokina AT-X Pro (or Pro II) 28-70mm f2.6-2.8 Pepe Guitarra Sold Items 2 05-12-2011 01:16 PM
For Sale - Sold: TOKINA AT-X 270 AF Pro II 28-70mm f/2.6-2.8 (Pentax - Mount) starvingjack Sold Items 5 04-16-2009 07:01 AM
All times are GMT -7. The time now is 05:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
