Originally posted by Nicolas06 The benefit of FA31 is f/1.8 (f/3.5 at same focal length for DA20-40 so almost 2 stops?), exceptional bokeh and rendering. f/3.5 is too limited at 31mm for subject isolation in many situations. For portraiture, for everything with a human skin inside or bokeh, I find it much better than DA20-40 or even the DA limiteds. This is also the most expensive prime in the lineup and the biggest limited prime lens.
If you don't use its assets, you should really think of selling it. Not only you'd get some money back for something you use more but you'd also make somebody else happy.
I do use the 31, when I am aiming for the best picture I can possibly take at that approximate focal length. And it has given me some of my favorite pictures, that I would consider the best. But also at times it has given me washed out colors, in the wrong light; less DOF than I needed; or strong CA that distracted from what I wanted. All could have been prevented or avoided with better technique, true. But with the DA 20-40 I've had those issues crop up fewer times. Partly because of how I use it, partly because my uses for it are different, and maybe a little lower expectations.
The DA Limiteds do tend to produce dense color saturation, so may not be ideal for most portraiture. Still they are fine tools that can be used for most purposes, and post-processing can certainly deal with saturation. I agree that sometimes the FA limiteds are a notch above, and I won't soon be selling mine. The DA 20-40 is what stays as default on my main camera, though.
