Originally posted by dcshooter If you disassemble the blades, then the easiest way to clean them is to drop them in a bit of organic solvent like acetone, mineral spirits, naphtha, etc. and let them soak for a bit. Just beware that acetone is hydrophilic, so if you leavet hem in there too long, they can rust.
Thanks, Brian, that's useful to know. I'll get hold of some naptha, I think. As it is, I cleaned each blade individually, with isopropyl alcohol and an old lens cloth. It was time consuming, but worked - the difficult part was getting the oil from around the little nubs.
When using solvent to soak the blades, I assume I need to flush them clean afterwards? Or does the solvent residue just evaporate?
Originally posted by dcshooter Cleaning in situ, I've heard that some have successfully used brake cleaner.
Not an option in this instance... whoever services the lens last must have used a very light oil, as it was thin and had flowed *everywhere*. I'm having to dismantle every single bit of the lens and clean it. It's good experience, I guess
Originally posted by dcshooter Once you step up to preset lenses with higher numbers of blades, it becomes increasingly fiddly. On some, it even makes sense to grease the blades to hold them in place while you put them in, then soak the whole thing in solvent afterwards to clean the grease back out. While it seems counterintuitive to disassemble if you are just going to regrease, it is still worth doing to remove solid grit and grime particles that may have entered the mechanism.
Interesting. Hopefully, I won't be attempting anything much more complex for a little while... my lenses with larger numbers of blades are currently oil-free, but this is handy to know for when - inevitably - I have to service one of them.
Thanks again for the pointers - very useful
