08-07-2008, 02:17 PM   #1
Front focusing with Tamron 17-50mm f2.8?
I recently bought a K20d with a Tamron 17-50mm f2.8. After playing around with it for a few days, I noticed my images were coming out a bit soft.
My first suspicion was an issue with the focusing, so I ran a tests using the D70 focus chart. It is definitely front focusing.
The thing is, I don't know if it's the camera or the lens. I've noticed a number of people have had front focusing problems with the Tamron, so I'm inclined to conclude that it's the lens. However, since the Tamron's the only AF lens I have, I can't test it for consistency.
Is there any way I can find out for certain it's the lens?
Wizzywig
08-07-2008, 02:36 PM   #2
- Put your lens on a camera that is good
- Put a lens on your camere that is good
Et voila.
08-07-2008, 02:58 PM   #3
Senior Moderator
Parallax's Avatar
There really isn't any way to tell for sure without access to a camera that is known to focus properly, or another auto focus lens that is known to be good. Since it is a K20, try using the focus adjustment menu. If the lens isn't so far out that it is beyond the adjustment range, you're fine.
08-07-2008, 03:11 PM   #4
QuoteOriginally posted by Parallax Quote
Thanks for the reply.
I set AF adjustment as far as it would go, and it still focuses slightly to the front.
I'll probably head to the camera shop to replace it. I just wanted to be certain it was the lens before heading in.
Wizzywig
17-50mm, front, k-mount, lens, pentax lens, slr lens, tamron, tamron 17-50mm
Tamron 17-50mm f/2.8 focusing problem kamocio Pentax SLR Lens Discussion 3 08-20-2010 04:01 AM
Tamron 17-50mm f2.8 Front focusing ? Part 2 eva2000 Pentax SLR Lens Discussion 6 12-23-2008 12:04 PM
Tamron 17-50mm f2.8 Front focusing ? eva2000 Pentax SLR Lens Discussion 21 12-22-2008 05:45 AM
Front Focusing - K200D + Tamron 28-75 - Who do I contact? cputeq Pentax DSLR Discussion 13 06-19-2008 09:48 PM
Front Focusing Mark Castleman Pentax DSLR Discussion 23 01-27-2007 06:24 PM
All times are GMT -7. The time now is 10:37 AM. | See also: NikonForums.com, part of our network of photo forums!
