Show Printable Version 9 Likes Search this Thread
02-28-2017, 06:46 AM   #16
Good looking shots!
02-28-2017, 06:58 AM - 1 Like   #17
Digitalis's Avatar
Any lens with shift capability is a massive advantage for architecture. Such a shame there are so few available for K mount.
02-28-2017, 09:07 AM   #18
QuoteOriginally posted by HankVonHeaven Quote
Good looking shots!
Thank you! It's 90% just being there.
I honestly hadn't thought about it until just now, but you're absolutely right. I hate taking photos and only realizing later that my perspective was just slightly askew.
02-28-2017, 09:47 AM   #19
bobbotron's Avatar
For sure. I always try to take advantage of the in body composition adjustment on the K mount bodies - it helps but if I'm being picky you still end up doing way more in post in some situations.
02-28-2017, 10:14 AM - 1 Like   #20
Otis Memorial Pentaxian
Any lens with shift capability is a massive advantage for architecture...
Though not so much for interiors.
The ongoing discussions regarding rectilinear ultrawide lenses for FF puzzle me, particularly in regard to architectural work and interiors. Low lineal distortion is not the same as accurate portrayal. Area distortion (aka volume anamorphosis), warping of curved lines beyond that attributable to perspective, and bizarre perspective are often the unhappy side effects of having to "fit everything in".* A less severe FOV combined with creative framing is often preferable unless one is aiming for novelty. Just my humble opinion
* It is not unusual to see water flowing uphill or cars with one side longer than the other with view camera work. More pertinent to this thread is one of the example photos above where there is an apparent "wavy" ceiling due to anomalous rendering of the light fixtures that escaped correction in PP.
02-28-2017, 02:36 PM   #21
I'm hoping that someone will develop a correction profile for the IRIX, as the default tools in Lightroom are more or less limited to basic barrel distortion and horizonal/vertical corrections, and it's tiring to apply these by eye each time. At some point it's a matter of Effort In vs Result Out.
But now I'm self-conscious. I'll have to give them another pass.
re: rectilinear UWA lenses, it's partially a matter of end goals. Most of the time, the photos exist to draw interest and sell a product. UWA shots exaggerate space in a compelling way and provide spacial context for the surrounding environment that no amount of creative framing with a 35mm can reproduce. I think it's important to provide a mix of fields of view, so I will generally provide 35-50mm handheld shots for details and fixtures on top of the 'show me the room' shots. I feel it works well.
02-28-2017, 04:51 PM   #22
Digitalis's Avatar
True, though for interiors Tilt is much more useful, mainly for its ability to extend DOF when using near-far compositions that are commonly used to give a sense of depth and spaciousness to interiors.
I agree, I have worked with the Canon EF TS-E 17mm f/4L lens and I find that lenses rendering characteristic draws far too much attention to itself. I have a preference for using the EF TS-E 24mm f/3.5L II due to the more neutral perspective - not to mention its superior control over distortion.
02-28-2017, 05:35 PM - 1 Like   #23
Looks great kvetcha
02-28-2017, 07:02 PM - 1 Like   #24
QuoteOriginally posted by kvetcha Quote
The photos look great and I was not intending to be critical. As you pointed out, tight spaces make it hard. I suspect that many of the commercial brochures for cabinets and decor use open-sided sets rather than "real" rooms to allow for longer focal lengths.
02-28-2017, 07:06 PM   #25
I have been curious regarding the TS-E 17mm and figured that the wide FOV is probably a little over the top even with perspective correction.
02-28-2017, 07:19 PM   #26
Digitalis's Avatar
I can confirm that even with corrections, the TS-E 17mm f/4L is over the top.
02-28-2017, 07:22 PM   #27
Cheers, and I don't mind constructive criticism! I definitely ran into a few instances where I could tell something was a wee bit off but the tools I had weren't granular enough to do a whole lot about it. The overall effect is fine for its intended use (a contractor's website), but I would certainly like to continue to hone my technique over time. Comments are always appreciated.
03-01-2017, 04:34 AM   #28
Quick update: I shot a message to Irix and they confirmed they are working on Lightroom lens correction profiles. So that's good.
15mm, aperture, estate, f/4, ff real estate, irix, irix for ff, k-mount, laowa, laowa or irix, pentax lens, shift, slr lens
Architecture Practicing for real estate photography SpecialK Post Your Photos! 3 01-16-2017 06:20 PM
New wide angle prime lens Laowa 12mm f2.8, or Irix 15mm f4 for K-1? David L Pentax SLR Lens Discussion 11 08-03-2016 07:10 PM
Real estate photography - photomatix hdr, flashes or simple hdr from camera panonski Photographic Technique 8 06-01-2016 03:21 AM
Lens for real estate photography Workingdog Pentax SLR Lens Discussion 25 03-07-2012 07:49 AM
15mm limited for interior/real estate photography? joeyc Pentax SLR Lens Discussion 25 07-08-2009 02:05 PM
All times are GMT -7. The time now is 11:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
