I have both the 28-105 and the 24-70. (don't ask
I have no doubt the 24-70 is slightly sharper in testing. But in the real world it is very difficult to see much difference. However, the 24-70 is an f/2.8 constant aperture lens. The 28-105 is a relatively slow one. If you need f/2.8 then there is no question. If you do not, then you lose some focal length on the wide end, 24mm is noticeably different than 28mm, but you gain a lot on the long end.
My ideal general use pair of lenses would be a 18- 35mm f/4 and a 24-105mm f/4 but we do not have either of those. So I usually carry the FA 20-35 and the DFA 28-105. Unless I need f/2.8 in which case I use the DFA 24-70.
Hope that helps.
Save
