Originally posted by hopkins802 I've heard good things about this lens! How is the MF ring in the AF version? I'm using this only for video and you said the MF version is a bit softer? I'm assuming a big enough lens hood would help with with flare? Distortion doesn't bother me.
Thanks!
Dan
MF on the AF version isn't bad, it's about a 120 degree turn, the ring is lightly dampened but IMO it would be better if dampened a bit more. It's decent action, though.
The MF version is a little bit soft in the corners, but through most of the frame it's very sharp. The two MF copies I owned performed identically, focusing action was stellar, and if I didn't luck out and obtain the AF version I would happily still be using the MF model.
It flares more than a modern lens, but is hardly a flare monster like its 28mm sibling. I used a cheap vented-style lens hood on mine and its fine.
Unfortunately I don't have any test pics I took with the MF versions, just everyday pics where there's nothing to scrutinize in the corners. The close focus capability is very nice.
