02-28-2017, 09:52 AM   #1
butangmucat's Avatar
Help Identify Several 3rd Party Lenses
Hello,
An elderly lady auditing one of my classes kindly gave me her unused set of ME Super, lenses, and accessories. I was able to identify the two Pentax lenses that it came with (M50/1.7, but sadly could be infested with a dot of fungus, and M50/2), however I was unable to identify these two lenses, and they don't exist in the forum database, either.
The first is a Soligor in the vanilla K mount, with no contacts or Ricoh pin, 35-140/3.8-5.3.
The second is also in the vanilla K mount, a Super-Albinon 28/2.8, with a MFD of 0.2m and max reproduction ratio of 1:4.
And it seems to be housed in the same barrel as my Ensinor 24/2.8 macro (right):
Have anyone used these lenses, and could any give some input on their performance?
Sincerely
02-28-2017, 10:03 AM - 1 Like   #2
photoptimist's Avatar
Slap them on your camera, take a few pictures, and tell us what you think in a quick review in the database! It's not hard to add lenses to the forum database -- about has hard as creating a new thread. A review can be as easy as you want it to be -- just subjective impressions of the lens and how it handles.
You may well be PF's expert on these lenses.
02-28-2017, 10:11 AM   #3
Google is your friend eg
Hin's Photo Corner: Albinar 28mm f/2.8 Macro Test Shots
02-28-2017, 10:16 AM   #4
QuoteOriginally posted by marcusBMG Quote
I don't think this is quite the same lens…
通过我的 Nexus 6P 上的 Tapatalk发言
02-28-2017, 10:18 AM - 1 Like   #5
Senior Moderator
BigMackCam's Avatar
I believe all of those lenses were sold under a variety of different names - they're pretty generic models; however, that doesn't mean they're bad lenses...
They're in lovely condition. I'm sure you'll have a lot of fun with them! As @photoptomist says, try them out and let us know what you think of them!
02-28-2017, 10:36 AM - 1 Like   #6
E-man's Avatar
I have that Super Albinon in a Minolta mount. Mine may say 'Super Albinar' but it looks just the same and is actually not a bad lens for what it is. Back in the heyday of consumer SLR cameras in the '80s and '90s, Albinar was kind of like Vivitar in that they sourced lenses from third parties and sold them under their own brand. The Ensinor lens could well be from the same manufacturer but sold through different retailers. In my area, Albinar lenses were sold pretty much exclusively by a catalog showroom store called Best Products. For a long time, I had assumed it was a house brand for that particular retailer but I've since learned those lenses were sold through a variety of outlets.
02-28-2017, 10:50 AM - 1 Like   #7
boriscleto's Avatar
The 28mm looks very similar to the Gemini that I had in the 80s...Probably came from the same factory, because like Albinar, Gemini was sold through a catalog showroom called Service Merchandise...
03-01-2017, 05:15 AM   #8
QuoteOriginally posted by dcshooter Quote
Well, this doesn't look promising:
"the worst lens sold" Soligor 35-140mm ?
Yeah but that's not quite the lens I have. I am assuming that Soligor sourced lenses from various different OEMs, which had similar or same specs but has various performances.
---------- Post added 03-01-17 at 06:02 AM ----------
Serial numbers... | Soligor MF Lenses - °Value° | Flickr indicates my lens was made by Sun. Never heard of this manufacturer.
03-03-2017, 11:58 AM   #9
Actually my copy doesn't look bad at all, at least on the telephoto end.
f8, 140mm, mounted on Sony NEX-6 via Mitakon Lens Turbo II
100% crop
03-03-2017, 01:15 PM   #10
Senior Moderator
BigMackCam's Avatar
QuoteOriginally posted by butangmucat Quote
Considering you're using a Lens Turbo II with it, which doesn't do the corners any favours, it looks pretty good to me. Certainly useable. I suspect it may be even better at the wide and middle parts of the focal length range too
03-03-2017, 01:56 PM   #11
I did crop this image a bit, will update 100% crop of cropped-out corners when I get back.
03-05-2017, 10:09 PM   #12
Without cropping, the edge doesn't look promising. But the center is pretty good.
Edge 100% crop
3rd party, k-mount, lens, lenses, pentax lens, slr lens, soligor, vanilla
K-3 AF Fine Adjustment and 3rd-Party Lenses fwcetus Pentax K-3 14 03-02-2016 11:44 AM
Help with 3rd party batteries raider Pentax Q 15 05-21-2015 04:44 PM
Best Lenses your opinion wanted 3rd party lenses 'non pentax' Krusty Surfer Pentax SLR Lens Discussion 58 02-20-2015 05:25 PM
HELP ! M42 lenses values ?3rd party pentax mount Pemarp Pentax SLR Lens Discussion 21 09-02-2010 04:53 PM
3rd party lenses mercyreaper Pentax SLR Lens Discussion 7 02-03-2010 02:30 PM
All times are GMT -7. The time now is 08:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
