Hi guys, I completed my repair of the FA*85 a few minutes ago and wanted to document the process for anyone willing to do the same.
Here's a
link to the album of images, as requested.
I bought a replacement gear from the link previously provided (actually have two spares now) and it arrived pretty quickly (PL to UK delivery). The tools required are: JIS Screwdrivers, New gears, Pliers, Sellotape, Flathead screwdriver ~2.5mm and (optionally) magnets.
Simple method, also use my images for a bit more detail:
1) Disassemble lens mount by removing 5 screws - be very careful to use JIS drivers only. Also take care with the pins. These can be taped so they won't fall off too easily.
2) Remove aperture ring (careful with the ball bearing).
3) Use pliers to pull out screwdrive shaft. The gear should remain in the assembly. This can be removed.
4) Take new gear and compare dimensions. This new gear is thicker and can be sanded.
5) Use force to push the shaft into new gear, away from the lens.
6) Place gear in the correct place in the assembly, then place the shaft over it and use force to put into position.
7) Re-assemble aperture ring (remember the ball bearing, this bit is the only annoying part).
8) Re-assemble the mount.
Hope these instructions help.
Haris
