03-10-2017, 05:17 PM   #1
Filter holder for Pentax D-FA 15-30mm and the IRIX 15mm lens ?
Is there a filter holder that will both properly fit the new 15-30mm and the irix 15mm firefly ?
Thinking about an IRIX 15mm lens while I ponder the D-FA 15-30mm later and buying a filter holder that could accommodate both would be super as I could buy the holder and filters now. But is there one that works properly for both?
03-10-2017, 05:34 PM   #2
Closed Account
I remember seeing this thread @mee and there looks like a few suggestions that might fit your needs. Hope this helps. Good luck.
Pentax D FA 15-30mm filter system - PentaxForums.com
03-10-2017, 05:36 PM   #3
Nisi, Lee, Firecrest Filter Square holder system are just a few
03-10-2017, 05:44 PM   #4
mee
QuoteOriginally posted by pjv Quote
QuoteOriginally posted by wed7 Quote
Yes I've been through that thread already and am aware of those companies. But what I'm not aware of is if anyone has definitively tested any one of those and confirmed one is swappable from the IRIX 15mm onto the Pentax 15-30mm without any extra adapters, rings, or gazonskis.
I'm also aware, for anyone playing at home , that the IRIX accepts 95mm round filters. But that is a waste to spend 100-200 bucks on a nice NDF that I'd only use on the irix. I'd rather kill 2 birds with 1 stone if possible and just buy a square 150mm system that works on a number of lenses without extras.
03-10-2017, 08:08 PM   #5
mee
Actually.. it looks like the Haida Holder (haha) has both a device that attaches to the Pentax 15-30 (Tamron but same fit) AND a 95mm adapter ring. It is pricey. But I think that'll do it unless someone has a cheaper option (always welcome).
03-11-2017, 12:14 AM - 1 Like   #6
gabriels's Avatar
QuoteOriginally posted by mee Quote
I have Haida and is a reliable piece of holder. It is big, but is connected with the size of the lens too. It is also more time consuming to install it compared with Cokin system and need to do it with the lens out of the camera.
03-12-2017, 05:55 PM   #7
The Haida holder works as my friend uses it, though I don't know if the part of the holder needs to be changed between lenses or can be shared.
I only have the Samyang 14 version of the holder.
03-22-2017, 03:45 PM   #8
mee
Thanks guys.
Actually I have another question -- What about a 100mm holder? Would that fully support the 15-30 (esp considering the smaller filter sizes) or does that lens require 150mm?
From my 'research', it seems the Irix 15mm can use 100mm filters since it accepts a 95mm circular filter (and 100mm > 95mm at diameter). And those 100mm filters and holders are quite a bit cheaper (and tidier) than the 150mm jobbies.
04-11-2017, 08:19 AM   #9
Irix also accepts gel filters behind the lens, if you want a cost effective starting point.
04-12-2017, 04:24 AM   #10
I have the Lee SW150ii holder and the adaptor rings for a few sizes (82mm, 77mm & the 15-30 holder), I've just sold my 15-30 to give the Irix 15mm Blackstone a try and have bought the 95mm adapter ring as the Irix has a filter thread, will let you know how I get on!
The only downside I see to this holder is the size of the filters but they're needed to cover the front element of the wider lenses and it works great.
15-30mm, 15mm, d-fa, filter, filter holder, holder, holder for pentax, irix, irix 15mm lens, k-mount, pentax d-fa 15-30mm, pentax lens, slr lens
Irix 15mm f/2.4 Lightroom Lens Correction Profile! kvetcha Pentax SLR Lens Discussion 9 08-20-2019 06:35 PM
Irix 15mm F2.4 Now Available for Pentax biz-engineer Pentax SLR Lens Discussion 9 11-23-2016 03:18 AM
New wide angle prime lens Laowa 12mm f2.8, or Irix 15mm f4 for K-1? David L Pentax SLR Lens Discussion 11 08-03-2016 07:10 PM
Lee Filters SW150 - Tamron 15-30mm adapter fits Pentax 15-30mm variant qdfb Pentax SLR Lens Discussion 5 07-16-2016 12:45 PM
Irix 15 2.4 perfect Wide Angle Lens for K-1? Interspieder Pentax SLR Lens Discussion 2 03-20-2016 05:04 AM
All times are GMT -7. The time now is 02:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
