When the issue mentioned above began occurring on my lens, it was somewhat noticeable if I gently physically pulled the aperture lever that protrudes beyond the metal lens mount. The lever didn't always 'snap back into place' with much conviction, and sometimes it didn't seem to fully complete that return trip. Overall, the spring action back to the starting position seemed very dampened. So the aperture lever probably didn't always make it back to the proper position before each exposure... some exposures would be accurate, but then a bunch would be underexposed. In the case of my lens, the issue probably just occurred as a result of actuations and wear over the years.
FYI, although the brief repair description above sounds like the recent mounting plate updates (and is in the same general area), I'm not even sure if the metal lens mount was replaced as part of my lens repair. But the structure just beneath it certainly was updated, because the aperture lever (that sticks out beyond the metal mount ring) worked perfect again after that, and then exposures begain working as expected again.
