03-14-2017, 12:25 PM   #1
greenas's Avatar
Something in a lens glass
Hi, I just got Tamron 80-200.
Can anyone explain what is that? Lens looks like new, front glass is perfect but from back there are some strange tiny bubbles in a glass. I do not see any problems with a quality for now, but I am wondering can it come some in the future?
EVA-L09  Photo
03-14-2017, 12:34 PM   #2
BullsOnParade81's Avatar
Fungus?
03-14-2017, 12:49 PM   #3
greenas's Avatar
QuoteOriginally posted by BullsOnParade81 Quote
Fungus?
Lens was stored in a original box with silica gel so I am not sure, but may be.
03-14-2017, 01:01 PM   #4
greenas's Avatar
QuoteOriginally posted by dcshooter Quote
If it looks like bubbles, it's more likely migrated oil.
Is it bad?
03-14-2017, 01:26 PM   #5
greenas's Avatar
Not as bad as fungus would be. Tamron coatings are very prone to permanent etching from fungus, whereas oil can usually be cleaned right off.
Would You recommend to take it to service centre immediately, or it is not a big issue for lens quality.
03-14-2017, 01:45 PM   #6
Ontarian50's Avatar
Yes, its oil that has deposited itself on the glass. This most often happens when lenses are left in a hot environment (attic, car trunk, etc.)
Trouble is, it's quite hard to get at the surfaces that are most affected. That Tamron will have to be stripped right down to its basic components. It's at least a couple hours work on a repair bench, and it can get hard to justify, economically.
03-15-2017, 01:06 AM   #7
Digitalis's Avatar
This lens has a reputation for being a decent performer compared to its peers. It would be well worth the effort to repair.
QuoteOriginally posted by Ontarian50 Quote
The image shows the problem from the mount end - the oil appears to be on the rear of the front cell of the optical assembly, so it should be relatively simple to get to.
03-15-2017, 08:02 AM   #8
Ontarian50's Avatar
If the OP's lens is the 2.8, then it justifies a few dollars more on the repair bench, for sure.
But the OP said the front glass was clean, and I'd bet it is. His photo is from the rear because that's where he can best see the oil residue - and I'll bet its on the element surface in front of the aperture assembly. For some reason that's where it always ends up, Tamron or otherwise.
03-15-2017, 08:07 AM   #9
greenas's Avatar
Is it really oil? Blades seems to be pretty clean.
03-15-2017, 08:56 AM   #10
Ontarian50's Avatar
QuoteOriginally posted by greenas Quote
Yes, it's a type of oil. However, camera lenses don't come "oiled" from the factory.
The grease used to lubricate the helicals and zoom cams can degrade and leach out a fine oil over time, especially if subjected to a hot environment. Vapour from that oil deposits itself on a convenient surface - which is usually the innermost and most inaccessible lens element. Its essentially a sweaty film that beads up on glass.
That's what makes the old Super Takumars so amazing. The darn things are pushing 50 years old, and the grease is still intact, and the helicals are still smooth. What wonderous grease Pentax used is a mystery.
03-15-2017, 10:25 AM   #11
greenas's Avatar
It is a Tamron Adaptall-2 SP 80-200mm f2.8 LD, so I think it is worth to be cleaned.
bench, bet, bubbles, camera, front, glass, k-mount, lens, lens problem, oil, pentax help, pentax lens, photography, repair, slr lens, tamron, troubleshooting
New glass - old glass. Which lenses should Pentax revisit? HopelessTogger Pentax Full Frame 204 09-07-2017 05:12 AM
Glass is glass right?? Raptorman Pentax SLR Lens Discussion 15 11-11-2009 01:56 PM
Something new, something old, something awesome! RaduA Pentax DSLR Discussion 18 03-06-2008 11:27 AM
Autumn colors - old glass is a good glass andrei46 Post Your Photos! 5 10-26-2007 09:35 AM
All times are GMT -7. The time now is 10:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
