Well, the title sums up most of my issue... But it is worth adding a bit more for discussion sake.
This is the version I have:
Tokina AF (235) 3.5-4.5/20-35mm version II. Lens Reviews - Tokina Lenses - Pentax Lens Review Database
On the K-1, this lens is pretty darn good. It's prone to flare when shooting in bright mid day into the sun, but that is usually because I am trying to provoke stars, and man, does this thing deliver stars like crazy!
Some samples from my first day out with it:
Post your K-1 pictures! - Page 320 - PentaxForums.com
In the above link pictures, I was just using my left hand to shade the lens, which actually works pretty good if you can multi-task well, but it get's old after a while.
I find my copy very sharp in the center across the range, and a little soft in the extreme corners @20mm wide open, and gets very good stopped down. Let's put it this way, I've seen worse output from some well regarded primes!
Mine didn't come with a hood. So far, I've bought 2 hoods. The first one I got was an original Tokina 77mm Metal shallow round hood.
It is scary screwing on the thing with that huge front element just waiting to be scratched, and it doesn't work too bad, but I'd really like a higher performance petal shaped hood to do a better job.
So, via Ebay, I grabbed one of those cheap and cheerful chinese petal 77mm threaded hoods with a pinch cap that goes on after the hood is screwed on.
This one:
FP92 77mm Lens Hood + Cap + Lens Cleaning Pen for Digital Camera DSLR SLR Lenses | eBay
I was so stoked that this would be the solution. But... it vignettes bad @ 20mm. When I say bad, I mean, the corners aren't dark, but I can actually see the petals protruding into the frame.
The seller listed it for a variety of Tokina lenses 28-70, 11-16mm, etc etc. so I thought surly it would work.
So, has anyone here found a working solution for their Tokina?
I am tempted to take a sanding block to the petals and just grind off some material ( I did say it was cheap, right?) and see what I get, but I'm afraid it's going to look like arse and I'm not sure if this grade plastic will let me smooth the edges very well. For the lousy $6 I paid for it, I'm inclined to go for it... heck, I'll still have the free lens pen they threw in. Heh heh.
Thoughts? Advice? Experiences? Thanks in advance!
Eric
