Originally posted by Mikeyotaku44 The lens I am using is: tamron af aspherical xr ld 28-300mm 3.5-6.3 macro. (If you copy and paste into google you'll see my lens)
OK, I have the Minolta AF-mount version of this lens, that I mainly use on an old Minolta film camera, but occasionally on my Sony digital bodies too. It's a useful and convenient lens, but - like many so-called "superzoom" designs - not exactly the sharpest bit of glass... especially at the long end. My first concern, then, would be adding a tele-converter to what is already a lens of optical compromises. I suspect it would produce quite sub-par image quality.
Originally posted by Mikeyotaku44 I assume the 6.3 is a one third stop? So a 2x teleconverter would push the aperture to just smaller than f11?
Not quite; two stops down from f/6.3 is f/13. In addition, because the focal length would be doubled from 300 to 600mm, you'd need a shutter speed of at least 1/600s (maybe even a little higher, for good measure) for hand-held shots, to avoid the effects of camera shake. Shooting 1/600s @ f/13 is going to require fast film and/or extremely good light. You'd be limited to the sunniest of days, I think.
If you're set on trying a tele-converter, I'd strongly recommend getting a good quality 1.4x or 1.5x model, and moving a bit closer to your subject. The degradation of IQ won't be so pronounced, you'll only lose one stop of light instead of two, and you'll be able to use a slightly lower shutter speed.
Have a read through some of the reviews here:
Miscellaneous Lenses for Pentax: Teleconverters (All Brands) - Pentax Lens Review Database
I've heard very good things about the
Tamron 1.4x Pz-AF and fairly good reports on the Kenko 1.5x Pz-AF converters, so you might want to look into those. I don't have personal experience of them, but I'm sure there will be other members here who can advise.
I don't know of any 2x converters that have good reputations. I own two old Russian M42 2x converters, purely because they're relevant to my lens collection, but I never actively use them
