All lenses are good within their capacity, including the kit lens 18-55. My father has it on top of its limited and it does a fine job. He has also the 18-135 that works just fine with fine AF and WR... And I had the 17-70 that is fine too. I found it a bit soft at time but now I learned that I was simply not very good at PP and even using my gear at that time.
If you really want quality, often primes deliver more than zooms. Even if they are not always (but often) sharper, they tend to render better and that's much more important.
If your pictures don't look stuning with the 18-55, outside of occasions where you really need a wide apperture, or a different focal range, this is really you the photographer that is to blame, not the lens. What a new lens can offer you is mostly wider apperture or different focal range. But that's about it. True the best lens will make a stuning shoot a bit more stuning and is far easier to buy gear than to become better if you have the money. But if your photo is so-so it will still look so-so whatever the lens.
Look at what some pro are doing with their kit lens:
Equipment and Where The Money Comes From | Zhang Jingna - Fashion, Fine Art, Beauty, Commercial Photography Blog
Now, what can appen is that you really think you need the best out there and can't be satisfied otherwise. Well the best is very expensive. That isn't the tamron 17-50. I mean it was easy to guess reading 5 second that is was smaller lighter, more conveniant then, but that it is screw drive and that it has field curvature. If you read a bit the reviews.
The next level obviously is the sigma 17-50. Bigger heavier with silent AF motor. But still we are still in "value" lenses that are truely great for their great price/performance compromize. But there NO WAY if you are picky you'll accept them as a substitute to the Pentax 24-70 + K1 for example.
At some point you can't be picky, looking for small issues, ask for wide appertures, the best AF and perfect sharpness and target entry level prices...
Yes maybe you should stick with primes, (I do, and not the worst by far), that a pleasure to use. But that just the cherry on the cake. I know that most of quality of my photos, or the lack of it, come from me. Not the gear.
