Originally posted by zapp I like my D-FA 70-200, I enjoy it on my K1 and did enjoy it on K3 with even smaller pixel pitch. In real world situations you can notice a slight drop in performance wide open at 200mm. What I do not like is size and weight of the lens. The big two can make lenses with same basic specs 200-300g lighter with no lack in performance. What really made me stumble is the Ephotozine Review of the two latest 2.8/70-200 lenses - shall we call them rivals. Nikon and Pentax and both tested on 36MP cameras, D810 vs, K1. Ok, they only publish numbers and I already like what i see from Pentax, but the Nikon resolves a lot more detail than the Pentax especially in the center of longer focal length. We are talking 10-20% higher resolution here and more. CAs are also just half of Pentax CAs.
Blame Ephotozine, blame me, blame Pentax. Considering that the Nikon lens is 325g lighter, or almost 20% less compared to Pentax, we can only clap and shear. Pricewise both play in the same league at least in the long run. If you calculate the weight difference between D810 and K1 you end up at more than a pound advantage for Nikon here.
my $.02
Honestly the difference in performance on the review is irrelevant. They are both more than good enough and the additionnal center performance would be only relevant if you where to use that 70-200 with a 2X TC and crop for wildlife.
The elephant in the room for all theses tests is that there as much variations between samples of the same model than between differents models and that different camera will have different default settings on the raw converter meaning different numbers. Want to increase your numbers by 20-30%, just add a bit more sharpening in your raw converter and its done. If you know how to do it well this will look natural. This is cheating? Well that the result that count and you have no idea how much "sharpening" is applied by default. Many things are involved there: the raw converter, the camera profile, the jpeg or even raws that may be sharpened directly in camera, a tiny difference in focus...
What is true on the opposite, is the size/weight aspect as well as the price. You could have 90% of what the Nikon or Pentax do offer with the old tamron screwdrive, avaible new for 600€, used for 450€ here. And it is 1kg instead of 2kg.
You have to understand where your priority. The best absolute performance, a great price, or the conveniance of something that isn't too big/heavy. A zoom already is conveniance. You may get better result on APSC with the Fuji 90mm f/2 wide open for 1/4 of the weight, 1/2 of the length and 1/2 of the price...
And really we spend lot of time on gear, comparing performance etc. But that because we look at 100% crop and so on. But this is completely irrelevant to the final product. People will not look at them on 8K screen for 10" away or print them 40x60" with a magnifying glass to look for small issues...
