In order to demonstrate the optical qualities of the
Vivitar Series 1 70-210/2.8-4 APO lens (which is
Version 6 of the VS1 70-210 MF zooms), a number of sample shots (taken with a Pentax
K-3 body) are provided here below. I am posting "unprocessed" resized versions of the originals (shrunk from 6016 x 4000 pixels to 1000 x 665 pixels), each followed by an "unprocessed" 100% (1:1) crop from each original (cropped at 1000 x 665 pixels but not resized). I am also providing some links below for anyone who wants to see any of the original images, straight from the K-3.
Here are some relevant notes on the samples:
1. All shots were taken handheld (which will explain the sometimes crooked horizons).
2. The only processing for the "unprocessed" resized "original" versions was the resizing and a bit of compression (to save a little bandwidth).
3. The only processing for the "unprocessed" 100% crops was the 1:1 cropping and a bit of compression (again, to save a little bandwidth).
4. No processing (either in-camera or post-) was employed at all on any of the full-size originals (not even any compression, so they are indeed a bit large, each about 10-12 MB, plus-or-minus).
6.
NONE of these images was processed for sharpening, contrast, gamma, color, etc., so that you can fairly judge just what the lens itself is able to provide. (Of course, under ordinary conditions, ALL of these images would certainly benefit from some processing, but that would interfere with the intent of providing these samples, right?)
7. EXIF info will be present in the images, but will be somewhat limited in value since the lens is a KA lens, and so some EXIF data will be missing, and the EXIF focal length values will not be correct most (or all) of the time anyway (since I often just set them to 150mm or 200mm most of the time).
Here are links to each of the original right-out-of-the-camera images, in the same order as the above:
http://www.allgeektome.com/pentax/v70210v6/20170323_101200_ori.jpg http://www.allgeektome.com/pentax/v70210v6/20170309_130719_ori.jpg http://www.allgeektome.com/pentax/v70210v6/20170321_122303_ori.jpg http://www.allgeektome.com/pentax/v70210v6/20170321_122305_ori.jpg http://www.allgeektome.com/pentax/v70210v6/20170323_104712_ori.jpg http://www.allgeektome.com/pentax/v70210v6/20170321_152454_ori.jpg Comments and/or questions are welcome.
Reason: clarification
