08-10-2008, 01:11 PM   #1
CPC Macro/zoom mounted on ist DL
I'm a newbie here and a novice with the lens so I'll apologize upfront if this is a basic problem/solution.
I just picked up a CPC auto zoom 80-200mm 1:40 CCT lens that was listed as compatible with my Pentax ist DL. The lens (which I think is a K-mount) does not "lock" into the ist DL body but swivels a bit when mounted. Subsequently the shutter will not atuate although the macro/zoom feature seems fine when viewed through the lens.
The camera documentation was of no help so any/all suggestions or help will be appreciated. TIA.
08-10-2008, 02:54 PM   #2
welcome to the forum
just a guess but perhaps the flange at the back is too big and is bumping the mirror
08-10-2008, 06:59 PM   #3
Checked that already and it doesn't seem to be the case. I appreciate the thought though, thanks.
08-10-2008, 09:07 PM   #4
Moo
Does it have electrical contacts on the mount? If not, set the custom menu option for "allow aperture ring use" to on, or however they are called...
08-11-2008, 09:44 PM   #5
Yes it has electrical contacts, however it does not fit the camera body. I've tried it on non digital Pentax SLR's (both Manual and AF) and it fits fine, just not on the ist series. It mounts into the body properly but does turn completely nor does it lock. Nothing seems amiss or bent and another more seasoned Pentax pro was puzzled also.
08-12-2008, 07:11 PM   #6
ChipB's Avatar
Sounds like the same problem some of the old Vivitar lenses have - on the back of the lens there's a protective flange on the outside of the actuating lever - if it's more than a 1/3 to 1/2 inch long it's hitting the light box inside the camera. Fairly easy to fix - remove it from the lens. It's not needed - or, for asthetic reasons, you can simply cut the flange down - I use a Dremel cut off wheel - with the flange OFF the lens - file the rough edges and hit the shiny edges with flat black paint - looks like it was manufactured that way.
Here's a pic of a Vivitar lens with the too long flange:
08-12-2008, 07:56 PM   #7
Thanks for the reply Chip although it doesn't seem to be the case here. This lens fits manual and AF non digi SLR's but does not fit the any of the ist digi's I tried it on. Here's what it looks like FYI...
08-12-2008, 08:26 PM   #8
ChipB's Avatar
Well, ain't that nuts!!
And the strange thing is that I'm sitting here holding the twin to your lens (at least the mount end - and I mean TWIN!!) and this lens fits fine on my ist DS and my K200D.
Sorry, shot my wad - don't have a clue!!
08-12-2008, 09:18 PM   #9
Blue's Avatar
If that lens is also for use on Ricoh, it could be the Ricoh pin causing problems.
QuoteOriginally posted by ChipB Quote
I have 2 copies of a 135mm f2.8 Sears lens that I bought new 20 years ago. One will mount on my k200d, the other damn near jams without completely turning and locking. Its the Ricoh pin in my case.
08-13-2008, 01:49 AM   #10
Thanks for the reply, that's sounds like exactly my problem alright.
Well, fortunately I found someone who can use this lens on a K1000 and I have a line on a newer replacement that I tried last week. It was puzzling though and i do indeed appreciate all the reponses. Thanks.
KJ
cpc, dl, help, k-mount, lens, macro/zoom, pentax lens, slr lens
My CPC Auto Zoom lens got stuck on my K20D mulberrybean Pentax SLR Lens Discussion 6 10-01-2014 01:37 PM
For Sale - Sold: [Worldwide] CPC 80-200mm 1:4 MC Zoom Lens dgaies Sold Items 2 02-22-2010 05:32 PM
For Sale - Sold: CPC 80-200mm f/4 Constant-aperture Auto KA-mount Zoom Lens, Only $20 wallyb Sold Items 4 09-10-2009 07:00 PM
For Sale - Sold: Takumar-A and CPC Phase 2 28-80mm f3.5-4.5 Zoom Lenses arpaagent Sold Items 2 01-30-2009 01:02 AM
All times are GMT -7. The time now is 12:08 AM. | See also: NikonForums.com, part of our network of photo forums!
