Originally posted by Sagitta . . .
EDIT: I just discovered some damage of some sort - the aperture lever is loose. I can physically push and pull it into the mount, and its all 'wobbly' now. I know it wasn't like that when I shelved the thing!
Until someone more experienced than I chimes in, I'll speculate a bit:
Before I reached your edit, I was wondering if the aperture was functioning normally? I had a similar situation with a Pentax 135mm lens. The focus ring was suddenly frozen. And the aperture also suddenly wouldn't stop down at all.
It turned out that an internal pin which was part of the aperture mechanism had broken and lodged in the focus helical gear. By removing the mount I was able to see the problem and get the broken piece out. The lens could then focus, but the aperture wouldn't work without the pin that broke.
If you have a set of JIS screwdrivers (
link), I'd suggest removing the mount and taking a look around.
To make re-installation easier, note the arrangement of the levers, etc. as you lift the mount off. And be careful not to remove the aperture ring in the process or you might lose the ball bearing that gives the ring its click stops.
I have a Vivitar 300mm f/5.6 lens which is, I believe, about the same as your lens (yours is K mount, right?). Except mine has a screw mount. So the innards of your lens will probably be different from mine, but here's a picture of my lens with its mount removed:
(click the image for a larger size)
Reason: another clarification
