04-04-2017, 03:10 AM - 1 Like   #16
In a previous thread on this subject this little device was recommended:
https://smile.amazon.com/gp/product/B00V5YLAXG/ref=oh_aui_detailpage_o03_s00...&ie=UTF8&psc=1
I live in a very low humidity area but spend some time every year in the SE United States and felt some fungus protection might be wise. This device is low in cost, fairly compact, and very easy to use, being recharged by plugging into a wall electrical box. I keep it in my camera bag most of the time. I've only used it a few months so can't guarantee it's effectiveness but based on the design and specs (it's claimed to dehumidify 500 cubic ft) I would think it's effective.
04-05-2017, 10:15 AM   #17
Otis Memorial Pentaxian
QuoteOriginally posted by wanderer2 Quote
Interesting...A housing for silica gel packs and indicator with a built-in electric charging element. Amazon sells several similar devices including one that promises "silent operation" (ROFL)
Thanks for posting. A pair of these along with a coated nylon stuff sack would be just the thing for a visit to the humid zones.
04-05-2017, 11:56 AM - 1 Like   #18
pete-tarmigan's Avatar
QuoteOriginally posted by Theov39 Quote
I have a Pentax DA 55-300 lens (first generation) that unfortunately has succumbed to fungus. Quite a bit is clearly visible across the different elements.
I am now storing it separately from my other lenses, BUT If I keep using this lens, can it 'spread' to other lenses if i use them on the same camera?
Can it also infect the camera?
No and no! Fungal spores are ubiquitous. You are breathing them in right now. To germinate, all they need is humidity, an appropriate growth medium (the coatings on optics) and warmth. See the link below.
Does my view finder have fungus growing in it??? - PentaxForums.com
When not in use, keep your camera gear in an environment with the relative humidity under 70% via a dehumidifier or in a container with packages of desiccant that can be heated to dry them out after use. More than one resident of the humid tropics has told me that they kept their camera gear with desiccant inside a bell jar sealed off with lanolin to prevent the humidity from from fueling rampant fungal and bacterial growth on the lens coatings. Tropical heat and humidity is the reason. Tinea Versicolor (a fungal skin infection) is common in the tropics but not in temperate or cold regions for the same reason. The fungal spores are present in the latter regions, but don't grow on the skin without the heat and humidity (and lack of personal hygiene).
As far as the camera body goes, the humidity poses a greater risk of corrosion of metal parts than of fungal growth because of a lack of growth medium.
04-05-2017, 01:54 PM - 1 Like   #19
QuoteOriginally posted by pete-tarmigan Quote
You cant teach these fungus fearing people, it is a complete waste of time.
04-05-2017, 04:28 PM   #20
MarkJerling's Avatar
I think you answered the question very well in that thread.
04-07-2017, 02:04 AM   #21
Thanks Pete for the advice! Will do!
04-16-2017, 11:42 AM - 1 Like   #22
You can find very small digital humidity meters at Ali express for under $1.50 each, including button battery. Listings change all the time, but to show what I had in mind, here's a recent finding:
Digital LCD Indoor Convenient Temperature Sensor Humidity Meter Thermometer Hygrometer Gauge Weather Station Monitor Hot Sale-in Temperature Instruments from Home Improvement on Aliexpress.com | Alibaba Group
FWIW, I once bought 16 for 1.18 each. Toi check them, I put them in a closed box, and after leaving them overnight, they all read the same, except for 2 that deviated by 1% of from the others.
You can also find reusable silicon dessicants there, also for ridiculously low prices.
bodies, camera, food, fungus, fungus in lenses, gear, glass, humidity, k-mount, lens, lenses, moisture, pentax lens, purchases, question, regions, risk, slr lens, spores
Lenses fungus??? IvanDiaz Pentax SLR Lens Discussion 3 02-16-2017 10:38 AM
Shooting a Contagious Milky Way image... interested_observer Photographic Technique 2 12-31-2014 07:41 AM
Pentax F 35-70 - keep perfect past-fungus or worse without fungus Dr.Gaga Pentax SLR Lens Discussion 2 04-25-2013 05:06 AM
Is lens fungus contagious? atekant Pentax SLR Lens Discussion 22 03-10-2012 06:41 AM
Huge test on the influence of fungus in lenses (on 9 lenses) CarbonR Photographic Technique 18 03-14-2011 10:34 PM
All times are GMT -7. The time now is 08:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
