Go to any lens testing website and you'll see results like this
Pentax HD DA 16-85mm f/3.5-5.6 ED DC WR - Review / Test Report - Analysis
If you want the sharpest possible image you'll shoot ƒ5.6.
The FA 31 is sharpest at ƒ2.8, the DA 70 is sharpest at ƒ4, the DFA 50 macro is sharpest at ƒ4 as is the DA 35 2.4.
However that being said, because of Depth of Field more of the subject may be in acceptable focus at ƒ8 than ƒ5.6, which may mean more of the image is sharper, even if it's not as sharp. But then the differences are probably not really noticeable in all the lenses mentioned. You're talking about differences you won't really see.
The 55-300 probably goes the other way being sharpest at ƒ8.
For the lenses I own, I shoot almost everything at ƒ5.6 when DoF permits. All these lenses have started the downward march to diffraction fall off by ƒ11.. most have fallen from excellent to very good by ƒ11. No lens good or bad is at it's best at ƒ11. You shoot ƒ11 for wider depth of field, not sharpness, although the shamrpness may possibly meet your needs for a particular shot.
The DFA 50 macro, sharpest at ƒ4....out of the excellent zone by ƒ11, falling off the charts by ƒ22, fairly typical excellent lens behaviour.
