Originally posted by BigDave You shot at F5.6 and F11. Wide open (or mostly so) and at the edge of where diffraction will start. It would be interesting to see duplicate images at F8 or so, where the lens may be its sharpest.
Kudos on the air density option. Shooting in a vacuum has its advantages!
Regards,
Yes, I chose those two pairs of pics (f5,6 and f11) because the difference in sharpness was most visible.
I did not shoot at f8, but at f7.1 and f9.
I thought those would be the sharpest, but they are not...in fact far from it. I shot between 30-35 pics and only a few are so sharp that I almost can read the telephonenumber on the reg. plate. (like pic no. 3 above is among the sharpest at f11). Most are OK'ish, and some are really soft.
So the softness/ sharpness is not dependent of f-number, which I supposed they would be, but is inconsistent through the whole aperture range. I even took some f18 which are among the best.
So varying air density is possibly the best explanation so far :-)
However I read about "shutter shock" or vibrations due to the shutter movement...can it potentially be a problem?
Attached f7,1, Iso250, 1/500s
