04-07-2017, 02:11 AM   #1
Need to put together a lens cleaning kit
Hi,
I need to put together a very good lens cleaning kit. What should i be looking for to go into this kit? Does anyone have a source for the parts i should get?
I am in Africa and have procured a A LOT of Takumar lenses. As you can imagine some of these need a good clean.
I cant get much locally. Maybe , i can find a can of compressed air locally - will check the 1 hour photo shop here. That's about all i can refer to locally - a 1 hour photo mini lab.
I will be airfreighting everything in so cant order stuff like cans of compressed air etc. Cleaning fluid is probably ok (need to check)
Any ideas/thoughts on what should be going into a hardcore lens cleaning station?
Also way way too many more Taks inbound to me. I gotta stop this or i will go blind ;-)
Thanks
04-07-2017, 02:53 AM   #2
i wouldn't use compressed air, you are liable to send dust inside your lens,use a camel hair brush and a rocket blower followed by lens cleaner and a microfiber cloth . F OR FUNGUS i USE ZIPPO FLUID FOLLOWED BY iSOPROPIL ALCOHOL.
04-07-2017, 06:40 AM   #3
Zippo Fluid?? Is this recognised as OK for the glass and its coatings? Sounds like a harsh treatment. But i dont really know, so have to defer to those who do.
How is the Zippo fluid applied?
Guess a bit of goggling is in order.
04-07-2017, 11:17 AM   #4
QuoteOriginally posted by dcshooter Quote
Zippo fluid is perfectly fine for Pentax coatings. So is acetone, although you will want ot keep it away form painted surfaces. aLso be aware that both can seep behind lens elements, so if you are clenaing from the exterior only, then use it sparingly on a lab graade wipe or microfiber cloth.
Are you planning on cleaning the exterior only or are you planning on disassembling?
For exterior, the best thing is a toothbrush and Armor All, Zippo for hard to remove dirt. If you disassemble, plain soapy water is just fine to use with the toothbrush.
For cleaning lens elements , get some kimwipes or similar lab-grade wipes.
For cleanign out helicals, nothing really beats an ultrasonic cleaner, but if you don't have access to one, a toothrush and hot soapy water, followed by Zippo will work well.
Avoid canned air. Either use a rocket blower or a compressor with an in-line particulate filter.
No wont be doing any disassembly. I need to clean front/rear elements and body/barrel.
Is there only ne type/formulation of zippo fluid? So if i can find it here, it will be the right stuff ?
04-07-2017, 01:11 PM   #5
QuoteOriginally posted by NedKelly Quote
I have used CVS WIPES ,just remember blow it brush it blow it and the gently wipe. OH by the way the less you clean the better as you will always run the risk of scratching it every time you clean it. It is something you should do as little a possible. But if you are worried bout zippo, stick to distilled water.Oh and if you are using a micro fiber cloth for crying out load make sure it is clean.
---------- Post added 04-07-17 at 04:13 PM ----------
I like the soap and water method, haven't tried the toothbrush yet.
04-07-2017, 05:11 PM   #6
chuck_c's Avatar
I have noticed that ultrasonic cleaners come in a variety of sizes. Based on your own experience, what would you consider to be the most practical size for cleaning disassembled lens parts.
04-09-2017, 09:48 AM   #7
At the end of the day ,once all the nasty cleaning is done I finish up with Windex.
04-09-2017, 10:16 AM   #8
chuck_c's Avatar
I use a 3L, but if you are working on smaller lenses, something as small as 1.5L would be fine.
Remember to use such a cleaner on the metal parts only, as it can damage the glass. Also be aware that the clenaer can remove engraving fill in paint, too, especially when using a stronger cleaning fluid in it.
Thanks for the info!
04-09-2017, 10:31 AM   #9
Just1MoreDave's Avatar
Look for naphtha, maybe in a hardware or paint store. The label might say "VM & P Naphtha" which stands for "Varnish Makers and Painters".
04-09-2017, 01:19 PM   #10
great info here ! Thanks
04-09-2017, 01:32 PM   #11
Ok my method is first use zippo or acetone followed by isopropal alcohol followed by Windex for sreak and haze free finished product. Also soap and water works well, just remember to let the elements dry for an hour or so.
04-09-2017, 01:34 PM   #12
JensE's Avatar
Maybe too obvious, so it hasn't been mentioned, but a vacuum cleaner for initial exterior cleaning in conjunction with a brush. You can e.g. clamp the nozzle to a table and hold the lens accordingly in front of it or use a DYI reducer to a smaller tube for better handling.
04-09-2017, 01:55 PM   #13
QuoteOriginally posted by JensE Quote
Nice idea sometimes you might get dust int the lens this way, but nice thought. The brush first is a must
04-09-2017, 02:04 PM   #14
JensE's Avatar
QuoteOriginally posted by niceshot Quote
You don't suck air through the lens, just perpendicular - very useful to get dust off those rubberized or grooved focus rings or (with just enough air flow) to quickly get any dust brushed loose of the front/rear lens so it doesn't scratch on the next move. So not after or instead, but in conjunction with the brush.
04-09-2017, 03:55 PM   #15
Yes it is good to clean it thoroughly like that first. As sand scratches,and will not make your day.
air, blow, check, cloth, elements, fluid, hour, k-mount, kit, lens, pentax lens, photo, slr lens, toothbrush, water, zippo
s.o.s. Humpty Dumpty Kit Lens- put back together? L.A.Williams Troubleshooting and Beginner Help 18 09-02-2015 10:16 PM
Nature Family the Swims Together Stays Together Jimbo Post Your Photos! 5 05-29-2013 07:57 AM
Finally put together my own website. Comments or Suggestions? Peteo General Talk 3 07-20-2012 12:07 PM
Ok, so how do I put this stuff together again? Skog Troubleshooting and Beginner Help 14 02-10-2011 05:17 AM
Was Asked How to Put Together A Fashion Shoot.. benjikan Photographic Technique 4 06-11-2007 07:31 PM
All times are GMT -7. The time now is 11:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
