Elegant DIY solution to the filter mount issue
I too like your project. I have been looking for a solution to adding filters to this lens. I realize your post is almost 3 yrs old, so do you have any usage experience results you can share?
Does this design effectively block out all light?
Except for the mounting ring which appears to be 3/4 in plywood, it looks like you used MDF to make the filter mount, what thickness MDF did you use? Is everything glued together?
How do you support/hold the 150mm glass filter against the filter mount? Do you have any finished photos of the mount?
Thanks in advance. This looks like a very elegant solution to this issue.
