04-13-2017, 01:15 PM   #1
cali92rs's Avatar
Pentax 16-85mm zoom ring stuck, doesn't focus
On my vacation to Hawaii i decided to take along my 16-85mm. The lens worked well until the last evening of my trip (thank goodness it was the last evening otherwise I would've been maaaaad).
It stopped focusing AND the zoom ring stuck! I could not even manual focus!
Any idea what is causing this and around how much it is to repair?
04-13-2017, 03:06 PM   #2
Canada_Rockies's Avatar
Were you in a very sandy area? You might have something stuck on the outside of the lens barrel between the two rings. Grab a magnifying glass and check carefully under good light.
04-13-2017, 05:37 PM   #3
Quartermaster James's Avatar
Did a seal come loose and catch the lens barrel?
04-13-2017, 05:52 PM   #4
I had my 16-85 zoom mechanism break under warranty. It would start to zoom out and stop around the 35mm mark. It would then be locked up. You could then take the lens and turn it upside down, off the camera, and hear something inside click. The lens would then zoom again until upright. So, try turning yours around at odd angles and see if it frees up and then locks again. Mine was under warranty, and Precision sent it back to Pentax, saying they didn't have the ability to fix it here. The repair description was vague and sounded like an issue with the barrel assembly.
16-85mm, focus, k-mount, pentax 16-85mm, pentax lens, slr lens
DFA 150-450 Zoom Ring Stuck nomadkng Repairs and Warranty Service 18 03-10-2017 08:10 AM
Stuck focus ring on Pentax-A 50mm F2 ZombieArmy Pentax SLR Lens Discussion 12 08-18-2015 02:00 PM
PK-M 50/1.4 ring stuck, back-plate screws stuck fungiman_md Troubleshooting and Beginner Help 4 05-10-2011 12:54 AM
16-45mm zoom AND focus ring stuck! mab18 Pentax SLR Lens Discussion 0 03-11-2010 08:21 PM
All times are GMT -7. The time now is 03:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
