Show Printable Version 6 Likes Search this Thread
04-17-2017, 06:13 PM   #16
QuoteOriginally posted by dcshooter Quote
Wow, I might be the first person to ever use this word correctly on a camera forum...
Have you considered trying a helicoil?
Cool! I'll have to remember these.
04-17-2017, 07:52 PM   #17
johnmflores's Avatar
Yes, helicoil. Does that make me the third to use the word? Maybe 4th?
I've used helicoils on bicycle cranks (stripped pedal) and possibly some motorcycle application that I can't recall at the moment. Both worked a peach.
04-17-2017, 07:53 PM   #18
DeepThrob's Avatar
QuoteOriginally posted by Kerrowdown Quote
Good grief... I now need a PhD to understand all that technical info
If you have a local automotive machine shop, bring it to them and they'll do it in 5 minutes...
04-17-2017, 07:54 PM   #19
I think what I would do is find someone who does aluminium welding to fill the hole and re drill and tap a new thread.
04-17-2017, 08:39 PM   #20
Could something like Manfrotto 293 Telephoto Lens Support to be adapted to fit the lens? It will dramatically reduce the stress on the collar, an d provide much better support and stability.
04-17-2017, 11:09 PM   #21
monochrome's Avatar
I've had indigestion all night just thinking about this. Couldn't sleep.
Well, that last bit might have been the check I just wrote and mailed to D.C.
But I'm sick over this. You can't even send her to Urgent Care in Tennessee from your place.
05-14-2017, 02:20 AM   #22
Transit's Avatar
Good grief... I now need a PhD to understand all that technical info.
and a shrink to sort through the innuendo
05-14-2017, 02:30 AM   #23
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Transit Quote
Even that comment is too technical for me...
05-14-2017, 02:38 AM   #24
RobA_Oz's Avatar
I missed this conversation, before. Have you resolved the issue, yet?
05-14-2017, 05:50 AM   #25
35mmfilmfan's Avatar
You leave your innuendo out of this, please
05-14-2017, 06:28 AM   #26
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by RobA_Oz Quote
No it's still a work in progress, not a lens used that often so it's not been a priority.
05-14-2017, 12:26 PM   #27
RobA_Oz's Avatar
OK. Depending on the condition of the foot after your previous attempt, post #13 here is the best general advice for a DIY fix, as a helicoil basically only takes you one step up in thread size (or they used to, when I was working on motorcars a long time ago). From the sounds of things, you may need to go further than that, but more substantial thread adapters are readily available on line. However, if you don't have a set of suitable thread taps at hand, I'd take it to a general machine shop or mechanic, and get them to do it for you, as a blind hole (one that doesn't go through to the other side, and which I think is the case here) requires a series of progressively larger taps to form the full thread. As you say, aluminium is comparatively soft and is therefore less forgiving of slight errors than steel, but the Loctite cited in post #13 is pretty good at filling gaps in worn threads, though even it has its limits.
05-14-2017, 12:28 PM   #28
PEG Moderator
Kerrowdown's Avatar
I think this will be route I'll be taking when I get around to it.
05-14-2017, 12:59 PM   #29
Transit's Avatar
QuoteOriginally posted by 35mmfilmfan Quote
wasn't mine mate
bush, check, foot, k-mount, lens, pentax lens, photography, replacement, slr lens
Food Guess what - its a Purple Majesty heirloom! debakarma Post Your Photos! 4 08-29-2018 08:25 AM
Travel Her Majesty`s Theatre Janse Post Your Photos! 3 04-22-2015 08:51 AM
Russian Mother Takes Magical Pictures of Her Two Kids With Animals On Her Farm alamo5000 Photographic Industry and Professionals 22 01-19-2014 11:54 PM
People Her Majesty "The QUEEN" benjikan Post Your Photos! 4 01-09-2010 07:36 PM
All times are GMT -7. The time now is 08:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
