I wouldn't be so quick as others to dismiss the DA18-135. To state the obvious, while the DA16-85 is better for framing in tight situations, it's also shorter at the long end, which might be more of a loss to you, depending on what it is that you're shooting. As noted above, having a look at the lens reviews, but probably more importantly having a look at the threads that showcase the lenses you're considering, will tell you more about their versatility and performance.
Here's a couple of the non-review lens threads, for example, with plenty of images to assist your thinking:
- For the DA18-135; and
- For the DA16-85
If you use the search feature, you'll find plenty more.
The advantage of the Pentax lenses is that many of them are weather-sealed, whereas the Tamron and Sigma ones are not, which may or may not be a consideration for you.
