Holy moly, that thing (135mm) is TINY.
It looks just under twice as long as the M42 adapter is wide.
On my current screen, it measures 86mm across the widest part of the threads and about 155mm in overall length, maybe take off 10mm for the amount that screws on inside the camera. So maybe 83mm long or 75mm jutting-out distance, assuming that the 42mm in M42 is the widest distance across the threads. Width is estimated at 45mm.
Those observations IMO constitute rough reality checks upon each other.
Compare my SMC-M 135mm f/3.5 which is 80mm from lenscap to mount face - in the ballpark for length - but whose width is more like 60mm.
It may amuse you to know that the pocket slide rule I measured and calculated all this with is Ricoh-branded.
Turning to the issue of a 28mm lens, I understand that there are convoluted reasons why lenses of the M42 era actually get BIGGER below a certain focal length, and the shortest wider-than-fifty M42 lens I have ever handled is my 35mm/3.5 Super Takumar. However, both lenses OP has here are rooted in the technological era of the Pentax M37's... in which there is nothing wider than a fifty. It took until well into the M42 era for Pentax to work that one out.
ETA For interest, here is a link to an ebay auction for a 35mm Fujita.
http://www.ebay.ca/itm/RARE-JUPLEN-FUJITA-35mm-f2-8-f2-5-LENS-M42-VINTAGE-FI...UAAOSwT-FZC2JZ
