05-19-2017, 06:19 PM   #16
QuoteOriginally posted by rgknief60 Quote
That's been my workaround. Only time it doesn't work are the times I forget there are florescent lights overhead.
Heh, I had few images ruined by that before I figured that es doesn't go well with some lighting. I'll try tomorrow, although I do prefer composing in ovf, but I guess whatever works now
05-24-2017, 01:51 AM   #17
Andrea K's Avatar
Last summer I tried to take panoramics with my K-1 late afternoon-sunset. Shutter speeds were slower up to about 250 or so. On tripod, SR was off, IR remote. Could not get sharp images. Didn't matter what lens. Finally gave up and used my K-5IIs. Wasted a lot of good light. Haven't been panoramic shooting with it since, need to take it out and test it again before warranty expires. Only got good panos fast shutter speed. Could be the reason Pentax came out with the ES option with the bios upgrade.
tripod, SR off, IR remote.... but no Mirror Lock Up or timer?
05-24-2017, 03:02 PM   #18
QuoteOriginally posted by Andrea K Quote
If memory serves, no. Did not need them for the K-5IIs, so expected K-1 to behave the same. It does not. Mirror lock up & timer don't always seem to help, only ES is reliable. Seems that certain mechanical shutter speeds ruin pictures. What's interesting is that long exposures (IR Remote, tripod) with mechanical shutter don't usually give me a problem.
05-24-2017, 09:08 PM   #19
You can test if it is mirror vibration by shooting with and without MUP and do so on a tripod to eliminate user variances. The standard text is to turn SR off when using a tripod unless there is considerable shake from wind, otherwise SR can actually cause reduced sharpness by trying to work against non-existing movement.
05-25-2017, 02:04 AM   #20
Andrea K's Avatar
uhm.. Sincerely you have to better try MLU or 2s delay.
05-25-2017, 09:23 PM   #21
Thanks for the advice.
aperture, causes, dfa 28-105 mirror, issue, issues, k-1, k-1 dfa, k-mount, lengths, lens, love, mind, ovf, pentax lens, result, results, shutter, shutter shock, slr lens, spec, speeds, weight
DFA 28-105 or DFA 100mm? surfar Pentax SLR Lens Discussion 27 10-06-2016 08:36 PM
Pentax K-1 Mirror slap issue? rlatjsrud Pentax Full Frame 146 09-05-2016 12:22 PM
Is the k-x mirror slap issue real? kyknos Pentax DSLR Discussion 31 10-29-2010 10:16 AM
6X7 mirror/shutter slap Gooshin Pentax Medium Format 21 01-15-2010 11:31 PM
(The Big shock) CANON 7D - NIKON D300S & PENTAX K-x ISO PERFORMANCE (The Big shock) starscream Pentax DSLR Discussion 21 01-14-2010 05:17 AM
All times are GMT -7. The time now is 03:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
