Originally posted by pres589 The 18-135 is not impressively sharp throughout its entire zoom range. Things start to fall off around 75mm or so and continue outward to 135. From about 20mm to 40-something it's quite sharp, especially stopped down a bit. It's a great lens. The Weather Resistant rating provides peace of mind that a bit of rain or snow is not going to be an issue.
That said, Tamron 17-50 is probably more useful as it goes wider and is faster, making it potentially a better fit for the uses listed. Current pricing is excellent as well. I wouldn't consider the Pentax 16-50.
Actually this needs serious clarification.
The 18-135 has better centre sharpness throughout it's entire range than any other zoom lens with it's range. In fact at every focal length, it's has measured excellent centre sharpness. It's edge sharpness falls off considerably after 50mm. It's rating is brought down by how soft the edges are from 85mm to 135mm. But when you consider neither the 17-50 or 16-85 don't include 85-135 in their range, I'm not sure how that should be held against the 18-135.
It's rated excellent or near excellent in 17 of 53 measured FL and apertures.
By comparison the DA 16-85 which folks are always comparing it to is excellent or near excellent in 17 of 45 measured categories, and it has more range. The 16-85 tends to be stronger edge to edge but not always.
At 24 mm the lenses are pretty close to even.
You can't make a direct comparison but it appears the Tamron 17-50 exceeds them both at 24mm as des the Sigma 17-50, but they are constant aperture 2.8 lenses, so sort of a different class.
So as i said before, go for the best deal you can find. You aren't going to be unhappy with the sharpness of any of these lenses. The weakest premium lens in this category on the test charts is probably the Pentax DA*16-50, and many people love that lens. Worrying about the sharpness of an 18-135 is just crazy. Why not worry about that lack of range in it's competitors instead? It's truly a one stop solution. With other lenses, there will be times you wish you had the extra reach and may even end up buying a second lens to cover it. I would really only consider a 17-50 type lens if i was also getting the 55-300 PLM. 50mm or even 85mm is just to short to be an everything all the time type of lens.
Any of the mentioned lenses will be great for flowers, the 16-85 and 18-135 are pretty good pseudo macro lenses, but for birds the 55-300 is pretty much the bare minimum. But you have the 70-300 so you're covered for now. You'll probably want to look for something a bit sharper in the future.
