Originally posted by moovinfast Hmm. Don't really want to spend $325 right now. The most I've spent so far is $170 for my 50mm 1.4 and before that the next expensive one was my zoom for $80. Did they make an older 1:1 like my SMC M 50mm 1:2 f2.0? Or am I just dreaming trying to get one for cheap?
Well, if money is and issue then another option you should consider is a good achromatic (multiple glass elements) close up lens such as the Canon 500D series close up lens or the Nikon 3T.
I use the Nikon 3T with my DA 18-55 and a 72mm 500D with my Tokina 24-200mm when I want Macro.
The trick is using a good achromatic close up lens rather than a generic close-up filter with only a single element. Achromatic lenses are in fact "lenses" because of the multiple elements.
This image was taken with the 18-55mm "kit" lens (the soft "version I") and the Nikon 3T.
