06-06-2017, 07:03 AM   #16
Fenwoodian's Avatar
QuoteOriginally posted by timw4mail Quote
What does 'haze' generally end up being?
I'm not sure, but my best guess would be crystalization/decompostion of the original glue.
It seems like certain lenses are prone to this. For example, one of the lenses I just worked on is a Voigtlander 75mm f/2.5 SL Color-Heliar. A quick search of ebay shows that there are a few of these lenses currently for sale. A couple of them have the same type of "haze" problem that mine had. That leads me to believe that maybe Voigtlander/Cosina used a lens element glue in their manufacturing process on this lens that would not hold up well over time, thereby condemning all of these lenses to a premature failure.
06-06-2017, 09:11 AM   #17
Otis Memorial Pentaxian
Full immersion into Dimethyl sulfoxide (DMSO)@ 120 °C for a few minutes should do the trick.
Regardless of its use as an alternative health remedy and industrial solvent, I suggest strong caution when working with DMSO. It easily penetrates skin and commonly-used hand protection and will carry any contaminants with it into the tissues.
By way of explanation, I was a biologist of sorts in another life and at one time the group I was working with explored use of DMSO for field extraction of pigments and other substances from marine algae (seaweed). We found it to work well, but were a bit disturbed to note that despite wearing fairly thick rubber gloves, even incidental splashes of DMSO onto the glove would result in almost instant garlic taste in our mouths (indicative of DMSO exposure). Part of the project was to do before/after electron micrographs (TEM) of the algal cells to establish the degree of cellular disruption, if any. The images showed profound disruption of both chloroplast and mitochondrial membranes. At that point, we decided that field use was not a good idea and scrubbed the project.
Dimethyl sulfoxide - Wikipedia
06-06-2017, 05:30 PM   #18
Digitalis's Avatar
I agree, dealing with solvents of any kind should be done with due care. The effects of DMSO on algal cell membranes and organelles really isn't surprising. From my lab training I recall Butyl rubber gloves are suitable for extended contact with DMSO, nitrile gloves can be used if you have an allergy to latex, however nitrile gloves have to be thick (or double up with thinner gloves) but they won't hold out for long against DMSO.
06-06-2017, 11:58 PM   #19
The whole instruction is on this website: Lens Glue , "To separate the older Canada balsam-glued lenses, simply place the lens in a saucepan (or coffee can), cover it with water, and put it on the stove and slowly bring it to a boil. In just a few minutes you will find that the glue has softened and the lenses have separated. For smaller lenses you will find that the action of the boiling water has enough force to shake the lenses loose. Larger lenses may have to be twisted or slid apart by hand (wear gloves!). Keep the lenses submerged, remove from heat, and let the glass in the water cool slowly. Do NOT get impatient and add cold water to the pan! The thermal shock caused by this rapid temperature change is enough to crack the glass. I learned this the hard way with a nice 50mm objective lens many years ago. It split the flint element neatly in half, right down the middle! After cooling, the residue of the glue is easily and thoroughly cleaned from the lenses with acetone, which leaves them ready for re-cementing." Eter pro narcosi is the best solvent for Canada balsam. But be careful- eter can cause fire.
06-09-2017, 03:29 AM   #20
Digitalis's Avatar
QuoteOriginally posted by JMMM Quote
Eter pro narcos
Don't you mean Ether Pro Narcosi? Personally I would not recommend this as a solvent due to the fact that Diethyl Ether* is highly flammable, and under certain conditions explosive. Diethyl Ether also has a really nasty habit of easily forming peroxides, the process of peroxide formation is accelerated with elevated temperatures and exposure to light and oxygen. If left to its own devices the resulting crystallized peroxides formed by Diethyl Ether are extremely sensitive to shock. According to reports amounts as low as 5mg are enough to pulverize borosilicate laboratory glassware. Put it this way: I'd rather work with Butanone.
* The MSDS I read categorized the scent of Ether as "Ethereal".
06-09-2017, 02:43 PM - 1 Like   #21
cyberjunkie's Avatar
QuoteOriginally posted by Fenwoodian Quote
Do you want to know a funny thing?
The lenses that have more problems with cemented groups, according to my experience, are Voigtlander. Not Cosina/Voigtlander, "real" German-made ones, like Apo Lanthar and Apo Skopar objectives made for large format and reprocameras.
Many, many examples show a very peculiar separation that looks rainbow-like.
It seems that Cosina did all its best to be as faithful as possible to the originals
Cheers
Paolo
06-15-2017, 05:05 PM - 1 Like   #22
Fenwoodian's Avatar
Latest Update...
Just finished cleaning the doublet, glued it back together and re-assembled the Voigtlander 75mm lens. Then I went outside and took about 60 test shots of my typical subjects.
Based upon a careful analysis of the test photos, I believe that I was successful in this first ever re-cementing lens element project. The images looked very good and now I've got a nice keeper lens.
Now that I've got one behind me, who knows, if I find another good deal on a lens I'd like to try with separtion/haze in it maybe I'll have to buy it and see if I can do it a second time.
06-15-2017, 05:15 PM   #23
MarkJerling's Avatar
Though if you're feeling bored, heat those two gasses up and you will end up with something that is categorically worse than the sum of its parts, chlorine trifluoride.
Yikes. That's some pretty mean stuff. (I had a read on wikipedia)
06-15-2017, 06:08 PM   #24
Digitalis's Avatar
Out of curiosity which adhesive did you use to re-cement the lenses?
06-15-2017, 06:28 PM   #25
mee
Congrats on your lens repair!
I bought a lens in UGLY condition. I didn't know it had haze in it or why it was listed in UGLY condition, but I found that out after I got it. I only bought it for parts but, for fun, I decided I was going to take it apart and clean the haze... easy peasy right? nope. Apparently FA zooms are designed to never be taken apart.. they are elaborate Rube Goldberg-esque builds.
So I got the parts I wanted (contact pins and springs), but never could get the lens completely apart. And now don't know how to get it back together. So I have lens parts and a half disassembled FA zoom on my coffee table... been there for months.
06-15-2017, 07:29 PM   #26
Fenwoodian's Avatar
I did some research, and ended up purchasing "The Original Super Glue - Clear Drying - Glass Adhesive". .06 fl oz and I believe it cost me $6 USD
It is water resistant, remains clear after cure and does not discolor. Service temperature range -40 to 150 degrees F
Cures quickly when exposed to sun or UV lights.
I applied it to the concave lower lens element in my dark basement. After placing the convex upper element on the lower element, the glue spread out evenly and without any air bubbles between the two lens elements. In the basement, the glue did not set up and remained in its' liquid form. The little bit that oozed out of the edges was easily cleaned up with acetone.
One warning.... It sets up IMMEDIATELY once you take it outside into the sun. After only about 5 seconds in the bright sunlight the two lens elements became firmly bonded. I left the elements out in the bright mid-day sun for about 5 minutes just to make sure the cure was complete.
06-16-2017, 12:45 AM   #27
Digitalis's Avatar
Interesting choice, but the results seem to be satisfactory. I would have gone for something specifically designed for optical components - but of course such materials suddenly command ten times the cost of regular adhesives soon as you add the phrase "scientific optical grade" in their description.
What did you use to align the elements?
06-16-2017, 08:39 AM   #28
Fenwoodian's Avatar
Just my finger tips and eyeballs.
06-18-2017, 12:12 PM   #29
Nice work! Thanks for sharing the story. Are the test photos at all interesting? Maybe before/after pictures?
06-18-2017, 01:06 PM   #30
JohnBee's Avatar
Latest Update...
Congratulations and thanks for sharing!
I've never owned or shot a Voigtlander lens personally, though I've often considered trying one out to see how it fared in the vintage collection.
With that said, what particular characteristics would you say these lenses have that make them attractive?
cause, days, elements, exposure, focus lenses, haze, irritation, k-mount, lens, lenses, pentax lens, slr lens
Light haze - is the bargain second hand lens with haze worth it? awscreo Pentax SLR Lens Discussion 4 11-05-2016 12:56 PM
Nature I'll Never Smoke Weed With Willy Again! Dewman Post Your Photos! 6 10-12-2015 12:09 PM
For Sale - Sold: SMC D FA MACRO 1:2.8 100 mm WR -----PRICE DROPPED again- again-again-again watchman323 Sold Items 12 12-09-2013 11:18 AM
I'll never bitch about lens prices again Fl_Gulfer General Talk 22 10-26-2009 06:39 PM
Never say "never"... maxwell1295 Pentax SLR Lens Discussion 7 04-18-2008 10:17 AM
All times are GMT -7. The time now is 12:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
