08-16-2008, 11:45 AM   #1
superbass's Avatar
Question on lens compatibility
Do the A series lenses work on the k200D?
08-16-2008, 12:26 PM   #2
Big Dave's Avatar
Yes. They work in auto exposure with manual focus.
Dave
QuoteOriginally posted by superbass Quote
08-16-2008, 12:37 PM   #3
Yes. As per photo.net, "A" designates a line of old manual focus lenses so you must use Manual mode on your K200D. A good tutorial is at: dpreview
08-16-2008, 08:02 PM   #4
superbass's Avatar
Thanks. I had someone looking to buy one of my lenses and they wanted to know if it worked on the k200d.
08-16-2008, 09:48 PM   #5
rfortson's Avatar
QuoteOriginally posted by the_indus Quote
"A" designates auto aperture, so it's not completely manual. You can set the aperture from the camera Av setting.
If it doesn't have anything other than "SMC" (or nothing at all) then it's a completely manual lens. You'll need to enable the use of the aperture ring in the custom settings of the camera, or the camera won't release the shutter.
08-17-2008, 07:24 AM   #6
rburgoss's Avatar
Sorry to interrupt here, but I guess there might be a little misunderstanding.
With K mount lenses, just check if the lens has an "A" setting in the aperture ring. If it does, then set the lens to "A" and use as normal AF lens, but with manual focus. You can use every single exposure mode available in camera. (Program, Av, Tv, Manual, etc).
If the lens does not have an "A" setting in the aperture ring, then you have to set custom function in camera to "allow use of aperture ring". In this case, exposure mode will only be MANUAL. No auto exposure modes will be available. But remember the little magic green button in ALL Pentax bodies. Just pick your aperture, press green button and you are in business!
Try to do that C and N, with 30 yrs old lenses. Bet you could not even mount them!
Robert
k-mount, pentax lens, question on lens, slr lens
Question on lens compatibility the other way around ismaelg Pentax SLR Lens Discussion 1 02-22-2010 01:28 PM
another lens compatibility question Deiberson Troubleshooting and Beginner Help 7 01-15-2010 08:43 AM
Lens Compatibility Question shnikies Troubleshooting and Beginner Help 1 07-10-2009 06:42 PM
dslr lens compatibility question cinaibur Pentax DSLR Discussion 7 03-12-2009 08:18 AM
Lens Compatibility Question elcahall Pentax SLR Lens Discussion 1 01-25-2008 08:38 PM
All times are GMT -7. The time now is 07:29 PM. | See also: NikonForums.com, part of our network of photo forums!
