I can't comment on the Prakticar, I'm afraid, as I've never used that model.
As for the Helios 44-2... Optically, it should perform very much like your 44M. In fact, subject to sample variation, it could perform just the same, very slightly worse or even very slightly better. I have several copies of both the 44-2 and 44M, and whilst I haven't scientifically tested them, my perception has been that the 44M may be just a little better in the borders, though resolution specifications are the same for both models. As for the amount of "swirl", there really shouldn't be any difference between the two. See
this earlier post of mine, comparing the 44-2, 44M and 44M-4.
One downside to the 44-2 when used on a Pentax body with flush-fitting, non-flanged M42 adapter, is that the rear part of the lens body (just up from the mounting threads) is too narrow to cover the "cut-out" areas of the adapter. As a result, you need to cover those gaps somehow to avoid light leaks and dust ingress. You can use bits of tape, a hair band, a rubber O-ring or any other method.
