Originally posted by jatrax Short answer is: probably. They will certainly work on your camera. But keep in mind that FA lenses were made in a different era and the line has both pro quality glass and absolute junk. If you buy a cheap 'kit' lens from that era you will likely be disappointed. However, the good glass in both the F and FA lines is right up there with anything you can get in the DA line, but usually (though not always) less expensive. Watch out for lenses that are really collector items now as the price is much higher due to the collector status.
These lenses are not optimized for digital but they do work. The coatings on older lenses are not up to modern standards and lens hoods are really important to use. They might exhibit more purple fringing than a modern lens. Also, they will all be screwdrive AF, so if you are looking for silent AF or in lens motors they have neither.
Check the lens database at the top of the forum page before buying.
The ones you have listed are all worth buying. The 85mm is a 'soft' lens with very specific uses, make sure you understand those before buying. The 100mm and 50mm macros are as good as you can get. The 200mm f/2.8 is excellent. The 135 f/2.8 is also as good as it gets.
Yes I know. I have read reviews, but still had some doubts whether they'll work without compromising image quality. But thanks for clearing that up.
---------- Post added 06-20-17 at 08:30 AM ----------
Originally posted by D1N0 focal length is focal length. The associated field of view is different. If you want to shoot wide angle you need a 24mm lens or lower. (But that is easily solved by just using the 18-55mm kit lens)
Well the kit lens aren't exactly that good, there decent enough.
---------- Post added 06-20-17 at 08:32 AM ----------
Originally posted by TaoMaas Any of those lenses will be fine on your K-S2. They'll probably out-perform your ability for years to come.
I'm counting on it. Don't want to spend loads of money on new lenses. Probably some FA lenses and some m42 lenses.
---------- Post added 06-20-17 at 08:35 AM ----------
Originally posted by D1N0 F and FA lenses are all autofocus and will work on the k-s2. The FA 85mm F2.8 is a special lens. It is soft which was hot in the eighties for people who liked to shoot playboy style. When you don't need AF you can look at Pentax-A lenses. They have automatic light metering but no AF. Cheapest to get are the Pentax-m lenses, you have to meter light manually in m-mode using the green button. Older zoom lenses are often cheaper than primes. None of these lenses were designed for digital but that doesn't really matter. The Ks-2 uses aps-c crop. There is an advantage to that because you are only using the middle part of the image circle, which is the sharpest part. Disadvantage is that there is very little wide angle available and lens aberrations appear larger because you zoom in on the image compared to film. There are also a lot of third party lenses that can be used. Take a look in our lens database:
Pentax Lenses:
Pentax Lenses - Pentax Lens Reviews & Lens Database
Third Party Lenses:
Pentax Lenses by Sigma, Tamron, Zeiss, and more - Reviews and Specification Database - Pentax Lens Review Database
Keep in mind that you need an adapter for the m42 screw mount lenses in the database.
Yes probably looking to purchase FA and FA* lenses if I get a good deal. Yes I know, I saw the Pentax made adapters on Amazon. I heard that ones made in Philippines had some sort of issue.
---------- Post added 06-20-17 at 08:37 AM ----------
Originally posted by xabolcs Hi!
Among the listed FA 100/2.8 and FA 135/2.8 were I used on K-30, both of which excellent lenses.
Post some pictures! I would love to see them in action. Image quality matters to me.
---------- Post added 06-20-17 at 08:40 AM ----------
Originally posted by clackers You're coming to us from the Canon world?
Welcome aboard.
Many of these lenses are excellent value.
Unlike the old Canon FD lenses, they will work perfectly well on your modern Pentax.
I myself use the FA35, FA31 and FA77 on my K-1, and was thinking about the FA 135.
Well have been trying to convert my friends too. But after being acquired by RICOH, Pentax limited it's operations in India. The Pentax K-70 costs just as much as Canon EOS 80D in India. Very bad move by RICOH. Hopefully they come to their senses soon. India is a big market.
---------- Post added 06-20-17 at 08:41 AM ----------
Originally posted by timw4mail At least at this point, there's a lot more excellent, used, full-frame glass than glass for crop cameras.
The only wrinkle is the crop-factor of the APS-C sensor.
Well it can be a boon in disguise. Depends on what angle you're looking at.
